[Project] Transit MK2 '78 rebuild
Postby Tomfish » Tue Aug 14, 2018 10:05 am
Hi,
After this post where I tried to decode the VIN number before I went to the RDW (Dutch DMV), I would like to start a new project topic. I visited the RDW last week and even without finding a VIN number on the chassis or slam panel I've managed to import it. They smashed a new VIN number in the chassis so it's all legal. Now I've got 8 weeks to get it ready for the MOT.
First step is to rebuild the drivetrain and brakes.
I'll keep you all posted.
Tomfish
Re: [Project] Transit MK2 '78 rebuild
Postby RustWidow » Tue Aug 14, 2018 7:35 pm
Wow good luck!
RustWidow
Postby Tomfish » Mon Oct 08, 2018 4:00 pm
Little progress. Got everything apart, having some trouble though with removing the kingpins of the front axle. I cannot get out the lock pin that is holding the kingpins in place. Any advice on how to remove them?
Also there seem to be some damage on one of the axles where the front hub slides on. Should I replace these?
Tomfish
Postby bulls in transit » Mon Oct 08, 2018 9:06 pm
Is that a 2002 in yellow?
bulls in transit
Postby dumper » Mon Oct 08, 2018 9:30 pm
Try warming it up with oxyacetylene or dril it out start in the middle with a small drill and keep getting the hole bigger try not to drill into the axle.
as you have the axle off the van and when you have the lockpin out you’ll be abe to get a good swing at it with a sledge hammer or even get it on a press .
Postby Tomfish » Tue Oct 09, 2018 8:13 am
bulls in transit wrote:Is that a 2002 in yellow?
Close, but it isn't a 2002...
You think this happened before? There seems to be a hole next to the pin that holds the kingpin in place.
Tomfish
Postby bulls in transit » Tue Oct 09, 2018 8:32 am
2 or 3 CS?
bulls in transit
Postby Tomfish » Tue Oct 09, 2018 11:25 am
bulls in transit wrote:2 or 3 CS?
1502
Tomfish
Postby bulls in transit » Tue Oct 09, 2018 11:27 am
Closer the first time!, but all the numbers are nice..
bulls in transit
Postby dumper » Tue Oct 09, 2018 10:37 pm
Looking at the way the head of the cotterpin is mushroomed over the grove in the kingpin was not lined up correctly or the hole in the axle was not cleaned up before hammering in the cotterpin you knock it out the opposite way it whent in
Postby Tomfish » Thu Oct 11, 2018 7:49 am
dumper wrote:Looking at the way the head of the cotterpin is mushroomed over the grove in the kingpin was not lined up correctly or the hole in the axle was not cleaned up before hammering in the cotterpin you knock it out the opposite way it whent in
Used a 10T press already but it just wont come out. Worried a bit though about the hole that is next to the cotter pin. I'm quite sure it should not be there...
Tomfish
Return to Mk 1 & 2
