Starter Motor to 1969 Perkins 4-108
Postby Ronnie_B » Fri Jan 11, 2019 10:36 am
Hi, I'm searching details about the starter for this Transit.
I was told it's a Lucas 45 so I searched the Internet and found a starter on AutoDoc that should be compatible.
I received it yesterday just to find out that...
The flange bolt pattern didn't really match.
The solenoid pointed straight downwards instead of upwards.
The motor was turned backwards.
So any kind of information regarding the original starter will be very much appreciated. :D
Ronnie_B
Re: Starter Motor to 1969 Perkins 4-108
Postby Neil » Fri Jan 11, 2019 2:01 pm
solenoid is usually mounted parallel on the starter body ?? just have your old one rebuilt makes things simple
Neil v6
Neil
Postby Ronnie_B » Fri Jan 11, 2019 3:18 pm
I don't have any old starter, that's my problem.
Skickat från min SM-A530F via Tapatalk
Ronnie_B
Postby Ronnie_B » Fri Jan 11, 2019 3:44 pm
Neil wrote:solenoid is usually mounted parallel on the starter body ?? just have your old one rebuilt makes things simple
Yes the solenoid is parallel to the starter body, but then depending on the assembly rotation the solenoid can be on top of the starter or under the starter, down to the ground. That's how this one came.
If I had a starter to look at life had been very easy and I could most probably quite easy find a replacement, my problem is I don't have any starter at all in the car. Just a big empty hole.
Ronnie_B
Postby Neil » Fri Jan 11, 2019 5:48 pm
any good ebay
Perkins 4108 starter motor
£ 36.00 - SOLD (17 bids)
Ended Fri Jan 11th  4:48pm GMT
Seller: l.schuy
or
Starter motor. Insulated return. From Perkins 4108.
Starter motor. Insulated return. From Perkins 4108.Starter motor. Insulated return. From Perkins 4108.£ 199.00 - did not sell
Ended Thu Jan 10th  5:08pm GMT
Seller: santanasusan
">£ 199.00 - did not sell
Neil v6
Neil
Postby Ronnie_B » Wed Jan 16, 2019 10:07 pm
Neil wrote:any good ebay
Seller: l.schuy
or
Sadly none of them fits a Transit MK1. :(
Ronnie_B
Postby jonochap » Wed Jan 16, 2019 10:17 pm
Have you tried Ralph? Ralph9 on here probably
jonochap
Postby Ronnie_B » Wed Jan 16, 2019 10:21 pm
jonochap wrote:Have you tried Ralph? Ralph9 on here probably
Hi, no I haven't, thanks for the hint. :)
Ronnie_B
Postby Ralph.9 » Thu Jan 17, 2019 7:35 am
I will have a look but I don't think I have one.
Ralph.9
Postby Neil » Thu Jan 17, 2019 8:11 am
Seller: l.schuy
or
the pictures was to give you a comparison
Neil v6
Neil
Postby Ronnie_B » Sun Mar 10, 2019 9:30 pm
I'm still searching, so if anyone has any idea it's much appreciated.
Ronnie_B
Return to Mk 1 & 2
