Gearbox in an mk2 MT75 or the old overdrive
Postby Ghosta » Tue Dec 01, 2020 8:07 pm
We got a mk2 LWB twin rear wheel. The old York out and a 2,5 80ps Td in . What’s my best choise keep the old 4 speed with OD or use the MT75?
Göran i Björnarbo
Ghosta
Re: Gearbox in an mk2 MT75 or the old overdrive
Postby dumper » Tue Dec 01, 2020 8:40 pm
If the o/d box is working ok I’d keep it with it working on 3rd & 4 th it’s like having 6 gears I fitted one to my mk3 great when overtaking change up a gear with out taking your foot off the gas .And it saves messing about with the van floor I think I’ve still got a new switch for the gearstick.
Postby Ghosta » Thu Dec 03, 2020 9:19 am
Thanks for your answer.
I don’t know if the figures are correct, but if they are . I think 3+OD is close to 4. Or is I’m missing something?
The overdrive is not OK today , something electric i think , checked the switch . But there’s something else messing.
In our old Volvos if there is problems with the Lycock we replace them with a 5 speed.
This is our old mk2 3500kg LWB twinweeler.
And the donor vehicle -96 mk5.
Bodywork is not a bit problem.
One idea with the camper is keeping the mechanical parts simple .
A Bosch conversion is on the schedule, I’m searching for a pump.
Göran i Björnarbo
Ghosta
Postby dumper » Thu Dec 03, 2020 10:45 am
Yes I used to miss out 4 gear changing up straight up to 4 overdrive and then dropping to 4th when needed to when go up inclines if it’s not working maybe fitting a 5 speed box will be more reliable less to go wrong.
Postby Adam mk1 » Thu Dec 03, 2020 11:04 am
You can also look up ratio on doner van, with vin number for example w8 =wide ratio box, C8=close ratio, and also 5th in ether box is not the same ratio so worth comparing with your overdrive box, always thought overdrive box is like 4&a half in overdrive, so 5 speed probably better anyway
Adam mk1
Location: Live in southsea Portsmouth, work nr Winchester
Postby Ghosta » Thu Dec 03, 2020 12:59 pm
I found this .
It says 0.82:1 on 5th on both MT75. And 4th+OD. 0.78:1
I’ll check the VIN plate if a remember.
Göran i Björnarbo
Ghosta
Postby Ghosta » Thu Dec 03, 2020 2:08 pm
A also find this somewhere over the rainbow.
Another thing, I think a comfortable speed in my old mk2 is not more than 55mph.
This will be our holiday car, no stress allowed on my holiday.
The mk2 will replace this one.
Göran i Björnarbo
Ghosta
Postby dumper » Thu Dec 03, 2020 3:11 pm
I’ve driven many transits with the MT75 box and I don’t know what the gear ratios were it may have been any of them or just one of them the company I worked for would just order what body they needed and a Diesel engine.
I’d just get a good box that’s the main thing to get right if you go down the 5 speed route or get your OD box repaired mate.
Postby Chug » Thu Dec 03, 2020 6:19 pm
I don't know if you've seen this site?
it's where that ratio diagram comes from
http://www.super7thheaven.co.uk/compone ... 5-gearbox/
Chug
Postby Ghosta » Thu Dec 03, 2020 7:39 pm
I found the site when a googled MT75 ratios.
VIN numbers. On my mk5.
I seen a key for reading VIN numbers, but a can’t remember where.
Göran i Björnarbo
Ghosta
Postby Chug » Fri Dec 04, 2020 9:41 am
Chug
Postby Ghosta » Fri Dec 04, 2020 12:59 pm
Thanks Chug.
Box 2 says E8 on my mk5.
Göran i Björnarbo
Ghosta
Return to Mk 1 & 2
