Alloy Escort Radiator?
Postby jckm2000 » Wed Aug 10, 2022 2:40 pm
Hi Folks,
My MK2 pinto is overheating, new pump, thermostat (tested), fan clutch etc. Only thing left really is the rad.
I quite fancy one of those alloy Escort race radiators, they're a bit smaller than the original though.
Has anyone fitted one? Are they up to the job?
Short wheelbase motorhome.
Cheers,
Jon
MK1 V4 flatbed (long gone)
1978 MK2 pinto
1996 MK5
2003 MK6 (now gone)
1967 Morris WF
jckm2000
Re: Alloy Escort Radiator?
Postby Neil » Wed Aug 10, 2022 7:18 pm
dont go smaller go bigger fit a di radiator
Neil v6
Neil
Postby dumper » Thu Aug 11, 2022 5:53 am
When I fitted a di radiator to my mk1 pinto conversion in winter I had to put a blind on part of it to get the heater hot enough.
Have you checked the if it’s flowing air and water through it it’s not blocked or the honeycomb fin’s are not breaking up.
As for a mk 2 escort rally radiator it should really be better if it’s one for 2.5 millington engine / 16 valve engine that they now use in them as the get a lot more hard work then a transit thought smaller they will have better air and water flow but maybe a lot more expensive then a new or reconditioned standard radiator
Return to Mk 1 & 2
