Hello
I had my leafs off the other dayon my 77 mk1 ci motorhome to do the engine swap. And i found that the front bushed on left and right spring are different sizes.
I have wanted to raise the front for a while to get better clearance on the belly, i kitesurf allot and often end up down tracks i probably shouldnt.
I was looking at getting mine re arched but as they look like a mis match pair i should probably start new if im goingnto spend the money re arching the pair to get the lift.
So if anyone has supplier or part numbers. Mine are the single parabolic leaf.
Or share any experienced if you have raising something like a mk1 on a solid beam axle.
The rear i will put airbags but i have been advised thats a big no on the front.
