MRspivvy wrote:It IS possible to fit a 5 speed to an essex. You need the 3.0 engine, type 9 gearbox from a 2.8i capri (but I would rebuild it first as it would be a bit marginal on strength with an essex engine's grunt) and this is the hard bit- you need to find a bellhousing from a 1972-74 ford consul 2.0V4.(has to be from a consul, other V4 applications are different) a few years back a firm called vulcan engineering remanufactured these, so I am sure theres one somewhere.
This bellhousing will fit the essex as the 6 has the same block as the 4 and will mate up to the type 9 5 speed. you would need to mix and match propshafts I think. not too sure on the clutch though. maybe essex cover with 2.8 capri plate?
