any idea????? no drive what so ever ,van run fine packed up then no drive attal ! plenty of oil in the box, (nice colour) linkage is working ok ,so is it box out and tourqe converter??????
Sounds like a stuck valve to me if all was fine before, jack the rear wheels rev it to about 3000 (optimum pressure) and drop it in D, if that doesnt clear it drop the oil and see if the filter is blocked.
But if theres a fault in the box and its dumping crap from the bands into the sump the filter screen is prob blocked, mines done it twice now after some heavy towing, but an clean and fresh fluid gets it going again,
is this a coffee and cream mk2 your having trouble with? think he's a bit upset its not running for gaydon... anything i can do this end after work this week?
well beefy he hasnt replied to my email so i cant get over now ! mate there is a possiblity it might be the linkage you might be able to take the 13m nut off and have a look ,some say the nut should turn with the selector! what we need to know is if it starts in all gears then the selector isnt working ,if it dont only in park and N then it must be the box!
