Leakin' Landliner!
Re: Leakin' Landliner!
Postby FredTransit » Mon Sep 01, 2008 8:48 pm
The only thing I can suggest is taking the tank off and fill it with water. Taking the tank iff is not going to be an easy job though, on enclosed bodywork.
FredTransit
Mk2 Trannyist
Postby jnwferguson » Mon Sep 01, 2008 9:56 pm
next time you fill the tank look underneath you should see fuel pour out check to see if there is a breather hose fitted tofiller neck if hose has gone you should be able to see a crack or hole in pipe look underneath use a torch check all round pipe it should be obvious if it is leaking also check hose clips.cheers jim.
mk2 4x4
mk2 camper
jnwferguson
Postby fremsley » Tue Sep 23, 2008 9:41 pm
Thanks to the marvellous help from watto this weekend (sorting we hope also the overheating by flushing loadsa gunk out of the rad) i think we may have solved the mystery of the tank - basically i filled it up too much an lost mucho fuel through the breather/overflow.
Cheers very much to Watto - a brilliant feller!
BTW - can anyone suggest a battery for my landliner - i think there is too much demand on the one I have - it powers everything when not hooked up (no seperate leisure battery fitted) Is there a heavy duty one i can fit?
Ta
Simon
fremsley
Postby chrisvmax » Wed Sep 24, 2008 10:21 am
Sadly, i never learnt the art and stuck more to the mental health nursing.
That could be a useful skill if your the owner of an old Transit :D
chrisvmax
Postby Watto » Thu Sep 25, 2008 8:47 pm
Thanks for the kind words mate - but did it work :?:
Watto
Postby FredTransit » Fri Sep 26, 2008 11:33 am
:lol: And perhaps a psychology degree as well!
FredTransit
Mk2 Trannyist
Postby fremsley » Fri Sep 26, 2008 8:46 pm
Watto wrote:Thanks for the kind words mate - but did it work :?:
Not sure yet - We're gonna take her for a spin out to Rye tomorrow - seemed ok on the way back from yours though. Lets hope there are no hills on the way!
Simon
fremsley
Postby fremsley » Sun Sep 28, 2008 11:45 pm
Didn't get as far as Rye - Just beachy head. No problems - No more than halfway on the temp gauge - brilliant! Had to drop to second gear for some of the hills tho'.
fremsley
Postby Watto » Mon Sep 29, 2008 8:16 pm
Great news 8)
There are some pretty serious hills if you went A259 route to Beachy Head. I reckon you done well to get up in second - I wouldn't complain at that :!:
Watto
Return to Mk 1 & 2
