Luke wrote:keep the front axle you have - just swap the link arms that are different- dont even unbolt it at the springs
petrolhead01 wrote:Luke wrote:keep the front axle you have - just swap the link arms that are different- dont even unbolt it at the springs
what about the hub that is linked to the steering box? is the steering arm not cast into the stub axle it self? also is there an advantage in fitting the twin wheel axle instead of my single wheel axle? cheers
Luke wrote:petrolhead01 wrote:Luke wrote:keep the front axle you have - just swap the link arms that are different- dont even unbolt it at the springs
no that bolts onfor a camper theres no advantage to the twin wheels - infact these days (with better tyres) theres no advantage to twin wheels at all even the 3500kg's have single rear wheels (unless its a chassis cab)
there are disadvantages tho - like diff ratios
Luke wrote:with a rover V8 i'd have thought you'd need the 5 stud ratios![]()
you can get anti roll bars but they are hard to come by - twin shock might help
