Rear Bearing Nut.
Rear Bearing Nut.
Postby imustloverust » Wed Aug 27, 2008 3:56 pm
Hello everyone,
I decided to replace a rumbling bearing on my 82 mk2 with type 34 axle today. I quickly ran into a problem with removing the nut that holds on the bearing. I know i should have a special tool but it costs 5o euro from e-bay and the haynes manual suggested the use of a "suitable drift". It would appear my drifts (cold chisel, large screw driver, metal bar etc...) are unsuitable. Anybody out there have any luck using a "suitable drift" and if so please let me know how you did it? Cheers all!
M
imustloverust
Re: Rear Bearing Nut.
Postby imustloverust » Wed Aug 27, 2008 5:47 pm
Update:
Solution: Bigger Hammer, Bigger cold chisel. One Slightly deformed nut! :D
imustloverust
Postby Luke » Wed Aug 27, 2008 5:48 pm
i bought the proper socket - for a lot less than 50 euro :D only problem is if its been off before the socket doesnt fit so i have to drift it off clean it up and put it back with the socket :lol:
Postby Gunslinger » Sat Aug 30, 2008 2:55 pm
yup, i found that too ... although i am not 100% sure the ones fitted to my mk2 twin wheeler were ford nuts, might have come off an ldv... either way, they now fit the socket i have :D
Gunslinger
Postby Hippo75 » Sun Apr 26, 2009 7:47 pm
I've the same problem - no special socket.
1. I'd prefer to use the special tool - does anyone know where I can get one?
2. the manual says use a "soft drift" - but some people have posted "bigger chisel/ hammer" - do i really have to do this? It's very tight - no chance it's a left hand thread is it??? (Near side rear wheel bearing)
Hippo75
Postby Luke » Sun Apr 26, 2009 7:53 pm
Hippo75 wrote:I've the same problem - no special socket.
yes 1 side is left hand thread .......... n/s one :!: way to check is imagin the nut is loose and the wheel is turning if it will undoo it then the thread will be the opposite way :idea:
i'd use a soft (metal) drift the softer the metal the harder it will be to come off but the less damage it will do :D
the proper socket i got off ebay it was an old stock one - at the time baconsdozen tried to find them but they are no longer manufactured - so if you get the chance of one grab it :!:
Postby baconsdozen » Mon Apr 27, 2009 7:47 am
Since looking for those sockets (which must have been a few years back because I've forgotten all abou it,) I've found somewhere prepared to make sockets in small batches.
What size are these ones?
baconsdozen
Postby Luke » Mon Apr 27, 2009 8:47 am
i'll measure mine up Kevin :D is it a UK company :?:
Postby baconsdozen » Mon Apr 27, 2009 10:11 am
Luke wrote:i'll measure mine up Kevin :D is it a UK company :?:
It gets better,they're in Sheffield!
baconsdozen
Postby manandvan » Wed May 06, 2009 2:06 am
hi i have one of these???? genuine churchill tools 30gbp check me out on ebay
i,m "manandvan" on there also.
by the way theres 2 types one for type 34 single wheel and one for type 51 52 53 axles.
type 34 is the castle nut type, r.h. = rh thread lh= lh thread
type 51 52 53 is a large hex nut, both sides r.h. thread
manandvan
Postby Luke » Wed May 06, 2009 12:17 pm
how many of the sockets have you got :?: the castle nut ones :?: are they still in manufacture or old stock :?: :D
i've actually got mine on my desk in front of me now - not got round to measuring it up yet but i have done a hardness test on it :D
Postby manandvan » Thu May 07, 2009 4:54 pm
hi ive got one i thought was castle nut (i did have both) but its the twin wheel hex nut one, genuine churchill tool ive had it since 84 when i worked for fords. 30 gbp if you want it ?? cant remember the last time i used it to be honest.
manandvan
Return to Mk 1 & 2
