GBBiker wrote:I have the Banana Di and I rarely see the needle move at all.
The only time the needle moves up the gauge tends to be when I'm stuck in traffic.
If you read my above post, I did a test dropping the wired up sender into some just boiled water. Do you think that should move the needle? I just don't know. Maybe this thing is working perfectly and my engine just won't overheat, but then again, the just boiled water is pretty hot, but water in the engine, under pressure would be hotter, right???
