DougT wrote:I would think that the sensible option would be to try and find a Mk1 or Mk2 pedal box and master cylinder - LHD. Like everything, these are becoming rare, but can be found after much searching. Hopefully the original mounting points are still there.
I've been watching ebay UK/Germany over the past weeks, but no pedal assemblies turned up - only for newer Transits. Some original(or remade) master cylinders yes, but no pedals. Transits were never sold in the Americas which makes it extremely difficult to get original parts.
Why would it be the most sensible option? because of ease of fitting?
I think a universal pedal assembly that suits my space and clutch requirements (all transmissions I could get have hydraulic clutches) may be easier after all - even if that means drilling more holes...
DougT wrote:Power steering is not standard. So that has been added - the common route is to take it from a mk3 but your vehicle may have it from something else. Engine out accounts for the wire between the steering column and the pump !
I'll need to educate myself on power steering before I can take a closer look at all the parts involved. Perhaps then I might figure out where it came from. But first I will focus on everything related to getting the engine power transferred to the tires.
Below picture shows the cockpit. Someone broke the side window and stole my stereo (now that that's gone, thieves have less incentive to break in
). But you can see that the steering wheel is not original. Previous owner told me the ignition lock came from a Mazda. Also the transit doesn't have a heater nor ventilation vents, so zero ventilation in cockpit.
DougT wrote:I cannot see clearly what else is around the master cylinder mounting, but maybe you want to consider if you need a brake servo as well and if it will fit. This will affect the choice of master cylinder. And if you are looking at brake parts then maybe a conversion to disc brakes if you see the parts available somewhere - is it Short wheelbase or Long wheelbase as disc brake hubs are different ? SWB is 5 stud and LWB is 6 stud. Disc brakes will need a servo.
It's a short wheelbase van. Here are some pictures:
https://image.ibb.co/cPfeQo/front.jpghttps://image.ibb.co/gPhR5o/back.jpghttps://image.ibb.co/dQc4rT/side.jpgAccording to the registration, it's a 1967 model and was imported into Colombia in 1974. However, I looked up my chassis number on motomobils table (
https://www.motomobil.com/ford-baujahrtabelle,7923.html) and that tells me it was built in December 1966 by Ford Germany in Germany.
I'll look into the brake conversion, thanks for pointing it out!
Last but not least, over the first 4000km consumption was around 12-15 mpg. Now it's 5 mpg. So I definitely have a problem.
