Starter Motor to 1969 Perkins 4-108
Postby Ronnie_B » Fri Jan 11, 2019 10:36 am
Hi, I'm searching details about the starter for this Transit.
I was told it's a Lucas 45 so I searched the Internet and found a starter on AutoDoc that should be compatible.
I received it yesterday just to find out that...
The flange bolt pattern didn't really match.
The solenoid pointed straight downwards instead of upwards.
The motor was turned backwards.
So any kind of information regarding the original starter will be very much appreciated. :D
Ronnie_B
Re: Starter Motor to 1969 Perkins 4-108
Postby Neil » Fri Jan 11, 2019 2:01 pm
solenoid is usually mounted parallel on the starter body ?? just have your old one rebuilt makes things simple
Neil v6
Neil
Postby Ronnie_B » Fri Jan 11, 2019 3:18 pm
I don't have any old starter, that's my problem.
Skickat från min SM-A530F via Tapatalk
Ronnie_B
Postby Ronnie_B » Fri Jan 11, 2019 3:44 pm
Neil wrote:solenoid is usually mounted parallel on the starter body ?? just have your old one rebuilt makes things simple
Yes the solenoid is parallel to the starter body, but then depending on the assembly rotation the solenoid can be on top of the starter or under the starter, down to the ground. That's how this one came.
If I had a starter to look at life had been very easy and I could most probably quite easy find a replacement, my problem is I don't have any starter at all in the car. Just a big empty hole.
Ronnie_B
Postby Neil » Fri Jan 11, 2019 5:48 pm
any good ebay https://www.ebay.co.uk/itm/303014586396&seller=&toolid=10018&37076415" rel="nofollow">https://www.ebay.co.uk/itm/https://www.ebay.co.uk/itm/303014586396&seller=&toolid=10018&37076415" rel="nofollow">https://www.ebay.co.uk/itm/https://www.ebay.co.uk/itm/303014586396&seller=&toolid=10018&37076415" rel="nofollow">https://www.ebay.co.uk/itm/https://www.ebay.co.uk/itm/303014586396 or https://www.ebay.co.uk/itm/292901155072&seller=&toolid=10018&37076415" rel="nofollow">https://www.ebay.co.uk/itm/https://www.ebay.co.uk/itm/292901155072&seller=&toolid=10018&37076415" rel="nofollow">https://www.ebay.co.uk/itm/https://www.ebay.co.uk/itm/292901155072&seller=&toolid=10018&37076415" rel="nofollow">https://www.ebay.co.uk/itm/https://www.ebay.co.uk/itm/292901155072
Neil v6
Neil
Postby Ronnie_B » Wed Jan 16, 2019 10:07 pm
Neil wrote:any good ebay https://www.ebay.co.uk/itm/303014586396&seller=&toolid=10018&37076415" rel="nofollow">https://www.ebay.co.uk/itm/https://www.ebay.co.uk/itm/303014586396&seller=&toolid=10018&37076415" rel="nofollow">https://www.ebay.co.uk/itm/https://www.ebay.co.uk/itm/303014586396&seller=&toolid=10018&37076415" rel="nofollow">https://www.ebay.co.uk/itm/https://www.ebay.co.uk/itm/303014586396 or https://www.ebay.co.uk/itm/292901155072&seller=&toolid=10018&37076415" rel="nofollow">https://www.ebay.co.uk/itm/https://www.ebay.co.uk/itm/292901155072&seller=&toolid=10018&37076415" rel="nofollow">https://www.ebay.co.uk/itm/https://www.ebay.co.uk/itm/292901155072&seller=&toolid=10018&37076415" rel="nofollow">https://www.ebay.co.uk/itm/https://www.ebay.co.uk/itm/292901155072
Sadly none of them fits a Transit MK1. :(
Ronnie_B
Postby jonochap » Wed Jan 16, 2019 10:17 pm
Have you tried Ralph? Ralph9 on here probably
Owner of not so troubled puk :)
jonochap
Postby Ronnie_B » Wed Jan 16, 2019 10:21 pm
jonochap wrote:Have you tried Ralph? Ralph9 on here probably
Hi, no I haven't, thanks for the hint. :)
Ronnie_B
Postby Ralph.9 » Thu Jan 17, 2019 7:35 am
I will have a look but I don't think I have one.
Ralph.9
Postby Neil » Thu Jan 17, 2019 8:11 am
the pictures was to give you a comparison
Neil v6
Neil
Postby Ronnie_B » Sun Mar 10, 2019 9:30 pm
I'm still searching, so if anyone has any idea it's much appreciated.
Ronnie_B
Postby Ronnie_B » Sun Mar 24, 2019 12:11 pm
Isn’t there anyone in this forum who knows what starter is used for this motor? I’m still hoping someone will be able to help me.
/Ronnie
Ronnie_B
Postby ventadorn » Sun Mar 24, 2019 9:34 pm
I have an old boat fitted with a Perkins 4107. When it came time to have the starter motor reconditioned I took it to a local place that specialised in motor rebuilds. They said it was a really odd motor that fitted the wrong way round and rotated opposite to normal and was only fitted to the mk1 transit. However they were able to recondition it as all the internal components were the same. So maybe you can try looking on UK boat forums where maybe someone has an old unit for reconditioning? There are still lots of these engines in boats here.
ventadorn
Postby Ronnie_B » Sat Mar 28, 2020 9:40 am
Thanks for your input. Knowning that even 4-107 can fit is good to know and can be helpful in my search.
Ronnie_B
Postby tranorak » Sat Mar 28, 2020 3:42 pm
This is how my 4108 starter looks if that helps you?
tranorak
Return to Mk 1 & 2
