Drop it
Drop it
Postby Sundowner » Sat Dec 03, 2005 11:00 pm
Has anyone dropped their transit a few inches?
whats involved, is it a matter of just resetting the leafs?
Mick
Sundowner
Postby MrMPuk » Sat Dec 03, 2005 11:01 pm
I just keep mine full loaded that helps it sit on the deck!
Postby cad69 » Sat Dec 03, 2005 11:14 pm
Good Morning
Don't you just attach the axles to the top of the spring instead of the bottom. Block it if you need it to be lower.
Cad.
cad69
Postby Sundowner » Sat Dec 03, 2005 11:27 pm
I want to drop it so the wheels fill the arches, yes a full load would get it down a little but the most it'll be hauling will be me the wife 3 kids and some tools
plus a car trailer with a TE cortina on it
The suspension is very stiff, it picks the left rear wheel of the ground every time i pull into my drive, I know lowering it wont stop this its more for looks and a little more stability
Cad i dont think the diff will fit between the rails and the springs if it where mounted on top
Sundowner
Postby cad69 » Sat Dec 03, 2005 11:42 pm
Yep, looked at the photo from your other thread. It would be a tight fit and you definately be bottoming out unless you put longer rear shackles on. Or leave diff as is and put smaller shackles on which may not get enought lowering distance. In NSW I believe you can't get rego (mot) if your axles are above springs, but I maybe wrong.
Cad
cad69
Postby Luke » Sat Dec 03, 2005 11:50 pm
MIne has a 1" raising block inbetween the leaf and the axle!! thats coming out if it looks too high other than that i think it would have to be re-drilled mountings!!! :? mabe?
while were on the subject since removing the Di and fitting the ointo i have found the front sits about 2" higher!! :(
Postby Sundowner » Sun Dec 04, 2005 1:38 am
Whats the go with the pinto conversion?
How come no one fits the 2.3 xr4ti engine?
I did one to a mk2 escort its a really easy swap i still have a NEW 2.3 sitting on my shed floor
Sundowner
Postby MrMPuk » Sun Dec 04, 2005 1:42 am
The only 2.3 we have here is the diesel!
Postby Luke » Sun Dec 04, 2005 1:45 am
Sundowner wrote:Whats the go with the pinto conversion?
mate pinto is temprary untill i fit 16v 2.0 dohc! :D
petrol is too expensive over here for a V6 daily driver!!! :(
whats 2.3xr4ti ?? V6 ?? we dont have them!! :(
Postby Sundowner » Sun Dec 04, 2005 2:12 am
No xr4ti ???
Its a Sierra but are 2.3 sohc turbocharged EFI 4 cyl, engine looks almost identical to 2.0 pinto except its about 20mm larger all over, bolts to 2.0 gearbox
And the DOHC head from a B234F volvo engine fits
http://www.rapidogroup.com/index.html
Sundowner
Postby MrMPuk » Sun Dec 04, 2005 2:14 am
I've never heard of the XR4Ti, must be an Aussie thing!
Postby FredTransit » Sun Dec 04, 2005 11:53 am
Personally I would only go up, longer and bigger. I don't do little or low, but it's all down to personal taste. As far as commercial vehicles go, we have enough unessesary attention as it is, without making the vans look like they are permanantly overloaded!
FredTransit
Mk2 Trannyist
Postby Sundowner » Sun Dec 04, 2005 12:18 pm
FredTransit wrote:Personally I would only go up
Yep that got to be an improvment :lol:
But some of us like to go around corners at more than 40kph without getting sea sick
They look awkward sitting high and raising them more would just be dangerous
But it would suit your van as you carry alot around and need the clearance but hey thats why polly bags where invented
Sundowner
Postby Gunslinger » Sun Dec 04, 2005 2:48 pm
Luke wrote:MIne has a 1" raising block inbetween the leaf and the axle!! thats coming out if it looks too high
if you do let me know as i might be interested in them :P
now as for the lowering thing, there is a couple of things you can try, some have been covered already
Rear
1) relocate axle over springs, but not recommended and a fair amount more work than you think
2) change the shackle length
3) Redrill the mountings to allow higher placement
4) change the springs :P ... not all will sit so high, or even get some tired springs :lol: i swapped my tired old springs out for some others and got a 2 - 3" lift :)
Front (not so easy as less space to work with)
Best i can think of is to redrill and relocate the hanger postitions, or possibly swap out the springs for those from a lighter engined van, those will sit lower
now for the bit always overlooked .... shocks, remember if you dont get shorter ones, then your original ones will be permanently compressed 1 - 2" more than they normally would be, this might lead to a stiffer ride
Gunslinger
Postby jay » Sun Dec 04, 2005 5:26 pm
xr4ti were a race type car in this country.looks like a normal xr4i rear wheel drive.its got a bit spoiler on the back and two small windows in the side rear.3 door sierra.xr4i have the 2.8 v6 in them but the xr4ti had the engine 2.3 4 cylinder with a dirty great turbo in. Andy Rouse has still got one he used to race it in the 1980s.
mk1 connect tourneo
jay
Return to Mk 1 & 2
