are the outer door sills structural ( mot failable)
Postby foggy08 » Mon Jun 09, 2008 6:59 pm
hi i recently had a garage look at my camper ,the guy said "it was all there" ....when i took it home i noticed n/s outer sill as very badly corroded to the extent i pressed it and put my fingers through it.in 2 places.... i asked another mechanic if that would fail an mot test ,he said not really ,as long as its 12 inches away from any body or seatbelt mounts . ,i always thought sills were structural .........is filler ok or should i get the sill replaced for its upcomming mot.....also does the exhaust on a camper need to reach all the way to the rear ,,,,,i fitted an exhaust but its short of the rear doors by about 24 inches,,,will i need to put a small extention on the back to make it clear the back....
ouch ..suarez bit my finger
foggy08
Re: are the outer door sills structural ( mot failable)
Postby FredTransit » Mon Jun 09, 2008 7:16 pm
The sills are not structural, so filer will be fine. Some testers might not even fail the van for it, but no need to make them obvious so it reflects badly on the rest of the van. Not sure about the exhaust, but it sounds fine to me.
FredTransit
Mk2 Trannyist
Postby toriitom » Mon Jun 09, 2008 7:23 pm
foggy08 wrote: ... i fitted an exhaust but its short of the rear doors by about 24 inches,,,will i need to put a small extention on the back to make it clear the back....
It is probably not a fail item but it is more of a health issue. The CO3 could possibly collect in the interior or the vehicle and poison the occupants. So for safety reasons I would extend the exhaust to the rear or thereabouts. :P
toriitom
Postby The Docmeister » Mon Jun 09, 2008 8:41 pm
My exhaust is short as well, was considering one of those exhaust trims that are slash cut facing down the way.
Otherwise it's deciding whether an extension should exit to the side or back depending on whether I decide to go for an awning or not.
The Docmeister
Postby Luke » Tue Jun 10, 2008 12:52 pm
i'd extend the exhaust too for the cost and difficulty it's a no brainer :D
Postby The Docmeister » Tue Jun 10, 2008 3:21 pm
The problem with the Travelhome is the door on the back . A straight extension would potentially let fumes in if you had to run the engine to charge up the batterries when parked up. An exit on the offside would be below the toilet compartment window and the other side would be the prime spot for an awning!
Must be a way around it, I guess somebody on here will have a CI Travelhome with extension etc. complete...
The Docmeister
Postby FredTransit » Tue Jun 10, 2008 3:23 pm
Maybe that's why it short, I don't think it's illegal, leave it as it is.
FredTransit
Mk2 Trannyist
Postby chrisvmax » Tue Jun 10, 2008 3:25 pm
I shortened the exhaust on my amby. it now exits about half way down the van out the drivers side.
Less pipes... less cash :D
Regards,
Chris
chrisvmax
Postby foggy08 » Tue Jun 10, 2008 3:45 pm
as the camper has a wooden floor and the exhaust is short ,would the rising fumes not enter the van when sitting in traffic...also the cab,can be entered from the rear so potential poisoning of me,,,,i think ill go for extention to the rear
foggy08
Postby toriitom » Tue Jun 10, 2008 4:58 pm
FredTransit wrote:Maybe that's why it short, I don't think it's illegal, leave it as it is.
Fred, I was not implying that it is legal or illegal, I don't know. :? All I was saying about is the POSSIBLE health risks with such a vehicle. :wink:
foggy08 wrote:as the camper has a wooden floor and the exhaust is short ,would the rising fumes not enter the van when sitting in traffic...also the cab,can be entered from the rear so potential poisoning of me,,,,i think ill go for extention to the rear
Foggy08, I cannot say whether or not the fumes could enter the inside of the vehicle. As above, I was just pointing out the POSSIBLE health risk with your type of vehicle. :wink:
toriitom
Postby Luke » Tue Jun 10, 2008 6:31 pm
end of the day fumes coming into the van say you leave the engine running while parked up then fall asleep you might never wake up :(
im not big on H&S but thats not something i'd do - just pipe it to the side rather than over the rear door :D
Postby transitexpress » Tue Jun 10, 2008 11:12 pm
If you extend to the rear make sure the tailpipe end is set to discharge below the rear bumper, as if it is set too high the bumper will divert fumes up towards the doors which dont have a gas tight seal.
I have had fume entry into double rear door minibuses in the past because of badly set tailpipes. :!:
Old transits need never die just keep mending em!
transitexpress
Postby The Docmeister » Wed Jun 11, 2008 11:38 am
This is a short wheelbase CI on Ebay and has a non-standard rear step, but it looks to me as though the exhaust comes out between the step and the light plinth. If so, it's very near the door and I think I'll be leading it elsewhere if I go for the extension piece..
The Docmeister
Postby chrisvmax » Wed Jun 11, 2008 4:17 pm
I'd route it out of the side of the van, that could be at the rear or halfway down the van as mine is. As long as it exits past the edge of the van it should be OK. I'll post a picture of what I did if I remember.
Regards,
Chris
chrisvmax
Postby FredTransit » Wed Jun 11, 2008 4:52 pm
chrisvmax wrote:I'd route it out of the side of the van, that could be at the rear or halfway down the van as mine is. As long as it exits past the edge of the van it should be OK. I'll post a picture of what I did if I remember.
Regards,
Chris
he's got a window on one side and planning an awning on the other so I don't think side exit is an option.
FredTransit
Mk2 Trannyist
Return to Mk 1 & 2
