diskbrakes
diskbrakes
Postby noise » Mon Aug 04, 2008 8:57 am
i am fitting a mk1 campervan whit front diskbrakes and i wonder if i have to change the master cylinder.
noise
Re: diskbrakes
Postby FredTransit » Mon Aug 04, 2008 11:51 am
If it's the 1978 you mentioned earlier I would say not.
FredTransit
Mk2 Trannyist
Re: diskbrakes
Postby noise » Mon Aug 04, 2008 1:58 pm
the van is a 1974 long wheelbase pickupp chassie. the brakes is from a scrapped mk3
noise
Re: diskbrakes
Postby FredTransit » Mon Aug 04, 2008 2:05 pm
Sorry I didn't see that one mentioned when I looked back through your posts. If it helps the first time we did this with an M reg LWB panel van we didn't do the servo. The van was a lot newer then though, so I know it was on the original 74 servo.
FredTransit
Mk2 Trannyist
Re: diskbrakes
Postby baconsdozen » Tue Aug 05, 2008 7:54 am
Easy choice.You can leave the servo and cylinder.
Or you can do the job properly and change them.
baconsdozen
Re: diskbrakes
Postby FredTransit » Tue Aug 05, 2008 11:19 am
Personally I wouldn't mend something that wasn't broken. I have to say the brakes worked fine for a good 10 years after fitting the axle.
FredTransit
Mk2 Trannyist
Re: diskbrakes
Postby baconsdozen » Tue Aug 05, 2008 12:45 pm
baconsdozen wrote:Easy choice.You can leave the servo and cylinder.
baconsdozen
Re: diskbrakes
Postby wardy-uk » Tue Aug 05, 2008 1:05 pm
I have been thinking about changing my front from drum to disk brakes. I have an adapted mk 3 master cylinder and servo of my Mk 1 ci. Would I just need a mk 3 axle now? And how difficult is it to do?
wardy-uk
Re: diskbrakes
Postby madmark » Tue Aug 05, 2008 1:23 pm
right the way to go on this is change the servo,
the origial drum servo isnt right for the job!
i am running the original drum servo and my brakes are rubbish! :wink:
every disc brake original van i have seen has a bigger servo than the original with the drum brakes! so mine is on my too do list! :wink: :wink:
Re: diskbrakes
Postby wardy-uk » Tue Aug 05, 2008 1:40 pm
To do it on mine would I need to switch the front axle :?:
wardy-uk
Re: diskbrakes
Postby FredTransit » Tue Aug 05, 2008 1:44 pm
luckily we don't have to decide, the SWB already has a Mk2 servo!
FredTransit
Mk2 Trannyist
Re: diskbrakes
Postby madmark » Tue Aug 05, 2008 2:43 pm
wardy-uk wrote:To do it on mine would I need to switch the front axle :?:
yes mate its the easyest way! :wink:
Re: diskbrakes
Postby wardy-uk » Tue Aug 05, 2008 3:21 pm
Whats axle do I need a mk 3?
wardy-uk
Re: diskbrakes
Postby madmark » Tue Aug 05, 2008 3:22 pm
:shock: :lol: :lol: :lol:
mk2 mate! :wink:
Re: diskbrakes
Postby wardy-uk » Tue Aug 05, 2008 3:24 pm
why a mk 2?
wardy-uk
Return to Mk 1 & 2
