fuel consumption 1 / carbs
Postby bazw » Tue May 15, 2007 3:07 am
this might cut through the confusion going on about the carb
http://www.innerauto.com/Weber_Brand/We ... arburetor/
it is a single choke 34mm carb with a 29 mm venturi
i dont know what the bolt pattern for the flange is, some more checking needed for that but its about right to swop onto the ford single barrel carb with 2 mounting bolt inlet
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby Rolo » Thu May 17, 2007 12:03 am
bazw wrote:this might cut through the confusion going on about the carb
It didn't with me; it just added to it.
it is a single choke 34mm carb ...but its about right to swop onto the ford single barrel carb
Is "choke" a synonym for "barrel" in the British Isles and can a carburettor have more than one choke (the type that comes on automatically or manually when the carb is under a certain temperature)?
Rudolf with his German English and his "sequential carburettor" made more sense to me since I understand a two or more barrel carburettor to work in a "sequential" fashion, with the second barrel taking over the job when a certain stage is reached.
Once Chinese English starts making more sense to me you Poms are in real trouble. :)
1973 drw; Falcon 250 c.i.; 12v fuel pump; belt-driven water pump & fan replaced with 12v water pump & two 12" fans; T5 gearbox; Mark II front discs.
Rolo
Postby bazw » Thu May 17, 2007 2:02 am
ok try this
the weber 34 ich is a single venturi carb with a manual or automatic choke plate for easy starting when cold
an as referred to "british" twin choke carb is a name given to a twin venturi carb (with 1 or 2 choke plates for easy cold starting ) and works as a compound (1 throttle plate[primary] opens before the secondary like a 32/36 dgav or works with both throttles opening at the same time like a 38 dgas
there that should be easy enough for an aussy beach bunny to grasp :D :D :D
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby Rolo » Thu May 17, 2007 7:10 am
I'll take that one under "advisement", as the judge sometimes says in U.S. TV shows. :)
Rolo
Return to Mk 1 & 2
