Mk2 Kingpins. Any short cuts?
Re: Mk2 Kingpins. Any short cuts?
Postby bortaf » Wed Jul 10, 2013 1:02 pm
:oops:
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby davev6newman » Wed Jul 10, 2013 7:44 pm
baconsdozen wrote:By placing a shim under the top cap it stops the assembly dropping down and takes up some of the movement present because of wear in the thrust bearing.If the wear is slight and the thrust bearing is still serviceable it is still a bodge but a workable one.
To drive out the king pin from the axle (where it often seizes on) you need a drift that is flat and almost the same size as the king pin or the end will spread making it impossible to shift. Ideally you need a large press,but using a really substantial block,a heavy hammer and large drift they can be got out,heating the axle end (within reason) will help.Use the block directly under where you are hammering so you are supporting the assembly and not trying to bend anything.
If you do use heat,a drop of water put on a component that forms a ball that runs about rapidly on the surface as it evaporates shows the metal is hot enough to expand about as much as it will and avoids damage by overheating it.
I've got one of these to do in a week or so,I'll try and remember to take some pics.
But your still saying to take the pin out? i need a quick fix without taking pin out to get mot.
davev6newman
Postby Muttley » Wed Jul 10, 2013 8:13 pm
Righto, get shims, cut out width of kingpin in shim, slide into gap at the top of the swivel. Shim up till u have no lift, get MOT dont leave it like that cos the thrust is collapsing, thats why you have lift :wink:
Expert burns receiver.
Bodger Extraordinaire!!
Fallen in love/hate with Mk6s
Muttley
Postby mb4ever » Wed Jul 10, 2013 8:16 pm
I think Bacon is telling you two seperate things Dave.
The first part, which I've left black, is about his ingenious "Bodge".
The second part, which I've coloured blue is about changing a King Pin.
Effectively, Bacon's offering you help to either bodge his way in black OR to change your King Pins in blue.
mb4ever
Postby davev6newman » Wed Jul 10, 2013 8:26 pm
:lol: i see :? Im sure looking like the thick one here :lol:
davev6newman
Postby davev6newman » Wed Jul 10, 2013 8:31 pm
Muttley wrote:Righto, get shims, cut out width of kingpin in shim, slide into gap at the top of the swivel. Shim up till u have no lift, get MOT dont leave it like that cos the thrust is collapsing, thats why you have lift :wink:
Thanks Muttley, you deserve a medal for that. He He He .
davev6newman
Postby bambi mk 1 » Wed Jul 10, 2013 8:50 pm
Just to throw a spanner in the works. Bodge an engine and it may STOP .Bodge the brakes and it may NOT STOP. Bodge the steering and it may NOT STEER.Two very sad words AYRTON SENNA. RIP.
bambi mk 1
Postby Muttley » Wed Jul 10, 2013 11:03 pm
Oh, it will steer, I ave done this many times, I have driven transits with collapsed thrusts and the STILL steer :wink:
Muttley
Postby bambi mk 1 » Wed Jul 10, 2013 11:25 pm
Yes Muttley they will drive without bearings and a lot of other things been there done that but unfortunatly in the so called world we live in today if something were to happen and the men with the wigs get us it will be a different story, could even be a life story :shock:
bambi mk 1
Postby mb4ever » Thu Jul 11, 2013 10:05 am
bambi mk 1 wrote:Yes Muttley they will drive without bearings and a lot of other things been there done that but unfortunatly in the so called world we live in today if something were to happen and the men with the wigs get us it will be a different story, could even be a life story :shock:
Merry Christmas to you too Bambi. :D
mb4ever
Postby baconsdozen » Thu Jul 11, 2013 11:07 am
As far as I know bodges come in two versions.
One...........The S.S. Safe and sound,a way of getting a bit more life out of a worn component or a 'different way of repairing. Some of the SS variety are so good that they end up as revisions in handbooks and workshop manuals.
Two...........The D. D Dangerously dodgy. In this category come grinding brake pipes to make them look shiny,making crap welding look good with an icing pipette and filler and pumping filler in a grease nipple to lake up slack,repairing chassic sections with fibreglass and filler etc etc.In fact thinking about it filler is involved in 90% or more of D.D. Bodges.
If the thrusts are only slightly worn,fitting shims to reduce the lift is (in my opinion) in the S S category. However if they are badly worn (and they can't really be inspected to see if they are breaking up in situ) it's going towards D D. But The only 100% proper way is to take the pins out and replace the bearings.
baconsdozen
Postby mb4ever » Thu Jul 11, 2013 1:21 pm
baconsdozen wrote:As far as I know bodges come in two versions.
In my book, a bodge, in this context, is something doing something with what's to hand to get a bit of breathing space before it's done right.
Dave's going to have to do his King Pins sometime in the not to distant future.
Well either that, or carry ever increasing amounts of lead on his back bumper to lighten the steering.
Unless of course, like Muttley, he can crack walnuts between his forearm and his biceps. :wink:
Bodging was a highly respectable and highly skilled trade until about 50 years ago when "Progress) put it out of business.
http://en.wikipedia.org/wiki/Bodging
mb4ever
Postby bortaf » Thu Jul 11, 2013 1:47 pm
I've done this loads of times on many motors and never ever has the steering seized, locked or fallen off, in fact every time i've had stiff steering it's been from the kingpins seizing not the bearing packs breaking up, it is THE trick to getting an MOT, even MOT testers will tell you how to do it, in fact it was an MOT tester who told me how to do it.
I can see why peeps wanted this done by PM, not cos it's a really dangerouse thing to do but to avoid the doom mongers :lol:
Current fleet
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby Muttley » Thu Jul 11, 2013 2:15 pm
Oh I wish there could be a return to "common sense" short cut was what Dave wanted, short cuts is what he got. I hope he has some of the aforementioned and knows what to do for the best and safest :wink: :)
Muttley
Postby mb4ever » Thu Jul 11, 2013 3:20 pm
Muttley wrote:Oh I wish there could be a return to "common sense" short cut was what Dave wanted, short cuts is what he got. I hope he has some of the aforementioned and knows what to do for the best and safest :wink: :)
Yes Auntie. :wink:
Trouble is, one man's commonsense is another man's :roll:
mb4ever
Return to Mk 1 & 2
