scorcher Imports wrote:Just installed a bosch 152 mechanical pump... all working...
Should be fine IMHO although more knowledgeable Transit 'bobblehats' will be able to advise.scorcher Imports wrote:Can someone please tell me if the mk2 Drive shaft is strong enough for turbo??... i´m a bit afraid by the looks... it´s really thin and small..
dumper wrote:My last reply was based on how strong the half shaft is if it is the propshaft the op is worried about my mate gave the van some serious abuse marshaling on car rally’s he once passed my location on yump on a Forrest stage fully in the air and this was where the rally cars backed off as it was so rough so I wouldn’t worry as long as there is no play in the u/js
bambi mk 1 wrote:dumper wrote:My last reply was based on how strong the half shaft is if it is the propshaft the op is worried about my mate gave the van some serious abuse marshaling on car rally’s he once passed my location on yump on a Forrest stage fully in the air and this was where the rally cars backed off as it was so rough so I wouldn’t worry as long as there is no play in the u/js
I know a fella who used do that with a mk 2 and Inever broke a prop or halfshaft but centres out of the clutch disc were another thing
Looking down at the tarmac through the windscreen a few times didnt seem to slow it down either
scorcher Imports wrote:Many thanks to all!!
The stock prop shaft will stay.. but i have one last problem... How to improve the top speed?
I have acess to a twin wheel mk5 axle but the wheels have a slight different bolt pattern that implies buying all 4 new tyres.... too expensive... can i install the mk5 pinion and crown in the mk2 twin wheel axle?
