Bigger brakes for my mk2
Re: Bigger brakes for my mk2
Postby conrod » Fri Nov 06, 2020 6:30 am
Frollo wrote:
Neil wrote:4 pot calipers is the upgrade if youve not got them now that should be plenty stopping power
I agree that should be plenty stopping power! This thing is rated to carry an extra 1600kg for goodness sake. I think the actual requirement by the norwegian traffic adm, is that you have the same diameter as the car you have pulled the engine from.
and the car you have pulled the engine from is?...
conrod
Postby Ralph.9 » Fri Nov 06, 2020 7:55 am
The hubs are different on vented disc's.
Ralph.9
Postby Neil » Fri Nov 06, 2020 8:21 am
extra 1600 kg ?? why,,, what engines in it what springs have you fitted
Neil v6
Neil
Postby conrod » Fri Nov 06, 2020 7:31 pm
Ralph.9 wrote:The hubs are different on vented disc's.
That pic I posted earlier of a 6 stud hub had solid discs fitted when I bought them, and I bolted those vented discs straight on. Here they are "as bought"
conrod
Postby Frollo » Wed Nov 11, 2020 11:51 pm
conrod wrote:the brake discs are interchangeable between the 5 bolt and 6 bolt wheels, it is just the hub/bearing carrier that differs. There is only two options here, either solid or vented discs. You can unbolt your solid discs and swap in a pair of vented discs. You will then need the wider calipers to go over these. The 190 LWB Mk2 had this setup from factory, so if you can find a set of those, then great. I have one of these vans, and it stops really well, even with a Supercharged V6! ;)
Another option, is to use the CALIPERS from a Daf 400 or LDV Convoy van, on the Transit discs. Again, these had the option of solid or vented discs, and single pipe or twin pipe calipers, so you need to be careful that they match. They are a larger caliper than the Transit one, take a larger pad, and the pistons are larger at 44mm vs. 41(?) of the Transit, which gives a hydraulic advantage, but they will still clear the 14" wheels (I have tried these)
Yet another option is that a lot of Range Rovers and LandRover Discoveries had a 4 pot caliper which I believe will bolt on and clear a vented discs. (Pre 2000 models) But I have not verified that for myself.
vented Transit discs on 6 bolt hubs
LDV Calipers
Do you recommend any place where you could get the LDV convoy calipers? and pads?
Cheers
Frollo
Postby Frollo » Wed Nov 11, 2020 11:55 pm
Its a OM606 from a G-class. And that wagon has some crazy discs...
Frollo
Postby Ghosta » Thu Nov 12, 2020 8:11 am
some crazy discs...?
OM606 from G-class some crazy engine...
Göran i Björnarbo
Ghosta
Postby Frollo » Thu Nov 12, 2020 6:18 pm
Ghosta wrote:some crazy discs...?
Göran i Björnarbo
Is this THE Dieselmeken?
Frollo
Postby Ghosta » Thu Nov 12, 2020 7:37 pm
Göran i Björnarbo
Me?
Göran i Björnarbo
Ghosta
Postby Frollo » Thu Nov 12, 2020 10:42 pm
Göran i Björnarbo
Me?
Göran i Björnarbo
Yeah, Göran who mentions OM606 makes me think twice ;)
Frollo
Postby Ghosta » Fri Dec 04, 2020 6:36 pm
Göran i Björnarbo
I’m sorry for a very late answer and I’m not THE Dieselmeken I’m an old farmer and loves the sound of a 6 cylinder inline Diesel engine.
Göran i Björnarbo
Ghosta
Return to Mk 1 & 2
