dumper wrote:You should have fuel in the top of the pump .what’s the oil level like I’ve had one with a pin prick in the diaphragm and let diesel into the oil and overfill the engine what’s the oil level like to much oil can give problems. I had a similar problem to yours on a A series with 4 cylinder York it had badly worn pistons and the crankcase pressure blowing oil passed the rings as well as pushing oil down the breather pipe into the inlet manifold it was so bad it blow oil out of the dipstick as well.
fingers crossed my problem will be solved..
shawn67 wrote:I decided to take it to a mechanic...and he has just gotten back to me saying it's it a problem with the injectors overheating...so for a total of €350 he will sort it out for me.
Thanks for all the helpfingers crossed my problem will be solved..
Sent from my moto g(9) plus using Tapatalk
