Mk1 alternator advise please
Re: Mk1 alternator advise please
Postby NogE » Fri Oct 08, 2021 8:09 am
Brilliant as always...
Got some options there Doug....I'll do my measurments etc....abit of plug adjustments, wiring....thank you very much doug..
NogE
Postby NogE » Fri Oct 08, 2021 5:36 pm
Also Doug,,
Bowersparts....great contact site for other uni bits...I'm into mk3 cortinas too..so a useful link there
NogE
Postby dumper » Fri Oct 08, 2021 6:14 pm
You used to get new plug kits for them Lucus used to do them.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby NogE » Sun Oct 10, 2021 7:59 am
Probably with them in the good old UK days
NogE
Postby NogE » Fri Oct 22, 2021 6:18 am
Hi again folks...hoping to keep you busy ...maybe this is why the mutleymk1 twat ripped me off :lol: .....
So I'm now getting into replacing this alternator....
Doug etc,I see we refer to needing a alt that has an external regular...that's this Lucas box on the bulk yeah?..
NogE
Postby NogE » Fri Oct 22, 2021 6:21 am
Thanks for your patience :D all
NogE
Postby NogE » Fri Oct 22, 2021 8:02 am
Defo a 11Ac ...thank you...(see pic)..
So I'll just look for an 11ac replacment...
Doug....thank you for all the camper twin charge info, defo a good heads up if I'm going to use camper facilities etc..
Thanks to all input on this...
Great helpful site this Luke..tops
NogE
Postby NogE » Sat Oct 30, 2021 6:42 am
Couple of updates..
Thanks for info on leisure battery etc Doug.i hv now invested in a relay trickle charge kit for leisure battery ,very simple kit to fit then fusebox, all yr bits off from that..
Alternator...
So mine is an 11ac Lucus unit..I got a full kit and rebuilt it...all good now....
Thanks for all help on this thread people
NogE
Postby DougT » Sat Oct 30, 2021 11:07 pm
Your picture from a couple of posts back does show the Lucas regulator (4TR) and there should be a couple of relays in the system as well. One of the relays controls the power to the regulator so that it stops generating when the ignition is turned off and the engine is still turning, and the other relay is to trigger the charging light on/off. Just so you know what they do, if anything starts playing up.
Great that you managed to rebuild it and see how you go. And great that you have gone the leisure battery route. I think it just saves worrying if you do use power.
Doug
DougT
Postby NogE » Tue Nov 02, 2021 3:25 pm
Thanks Doug....all good stuff to know...
NogE
Return to Mk 1 & 2
