mk11 brake fluid reservoir
Re: mk11 brake fluid reservoir
Postby Soren » Tue Nov 22, 2022 7:16 am
Good info :)
Transit MK 1 1977 Essex V4 2,0 Autocamper
Volvo V60 D2/D3 2013
Harris Magnum 2 GPZ 1100 1984
Kawasaki GPZ 1000RX 1988
Aberdeen Angus cattle approx 35
MF 135 1973
David Brown / Case 1390 1982
Soren
Postby Neil » Tue Nov 22, 2022 8:39 am
yes some of last of the mk 2 s had bendix servos fitted , a lockheed servo will interchange as i fitted one while mine was rebuilt
Neil v6
Neil
Postby MinorMatt » Wed Dec 21, 2022 4:06 pm
That looks very like the 1991 - 1997 transit brake reservoir too - but the caps/low fluid switch are cosmetically different
I'm sure I have a used one on the shelf
Lucas Laser 2000 & IDS
95 N Hallmark (white)
96 P 150 TD 100PS LWB Hi-Top
96 P Autosleeper Duetto
2 x 2006 Mk7s
Postby MinorMatt » Wed Dec 21, 2022 4:08 pm
Also worth a quick look?
https://www.fordopedia.org/parts-catalo ... -mk3/E2.10
Chasing this through part numbers....
https://www.ebay.es/itm/194339239818
It appears as though the variant without the "tag" underneath was superceeded with the one that does have the tag. On one of my vans I met this incompatibility and the later reservoir fitted perfectly on the earlier master - but is a touch larger
2 x 2006 Mk7s
Postby MinorMatt » Wed Dec 21, 2022 4:41 pm
2 x 2006 Mk7s
Postby yardcommander » Mon Jul 17, 2023 10:30 am
To every one who has replied, thank you. I got logged out months ago and couldn’t get back in till now. Will look at all the suggestions posted for me. Again thanks
yardcommander
Return to Mk 1 & 2
