hi guys.. newbie here
hmm
Postby rottie_007 » Mon Nov 14, 2005 9:12 pm
I reckon 50mm box would be better to be honest......
anyways....
I am gonna have a go at doing a driveway repair to get her back... or try and borrow a low-loader from somewhere
1979 mk2 pre facelift CI campervan " Bessie Brown "
1994 Pug 405 est " George "
1998 pug 106 "Mildred"
rottie_007
Re: hmm
Postby Luke » Mon Nov 14, 2005 9:26 pm
rottie_007 wrote:I reckon 50mm box would be better to be honest......
i reckon an A frame would be better still!! :lol:
a frame.......
Postby rottie_007 » Mon Nov 14, 2005 10:19 pm
true an A frame is ok, but with box steering i have found the massive lock available can make the a-frame not do as its told... had an a60 on one once that went to full lock under a tight manouvre... never again...
ill figure something out...
my local shop has wheel cylinders for a tenner a piece
but wants 20 a shoe to reline them? am I right in thinking its twin cylinders at the back as well as the front?
rottie_007
ok come on I need to pick brains here
Postby rottie_007 » Tue Nov 15, 2005 7:42 pm
re rear brakes and propshaft, has nayone got a local motorfactor who lists the brake parts for a mk1 lwb tranny?? mine lists cylinders only, no shoes and definitly no propshaft Uj's
help guys.....
rottie_007
tranny
Postby rottie_007 » Sat Nov 19, 2005 6:06 pm
well lhad to work today so didnt go to see the van...
will be calling the owners later to arrange a viewing for tomrrow...
I will of course post lots of photos of what will hopefully be my new van !!!
rottie_007
Postby Gunslinger » Sat Nov 19, 2005 11:54 pm
the shoes you'll find on ebay (they come up fairly regular) not much help i know if you need them quick, as for the uj's i cant help i am affraid, unless a mk2 prop from a 2.4d lwb minibus will fit (it needs the centre bearing doing i think (about £30 for all three parts of the bearing) but i cant say 100% about the uj's as there was a lot of noise coming from the diff :D
Gunslinger
ive been and now need to decide...
Postby rottie_007 » Sun Nov 20, 2005 3:41 pm
conversion is by a company called wilson
it has clean front wings... chassis is perfect... doors are a bit ropey round the side trims (borders on blue bit) it smells damp inside, its got no coolant in the running v4 engine, 6 good tyres, absolutely crap bonnet, no brake pedal so no doubt its all dry and has been since he bought it in january.... e reg...
front discs !!!
shes only about 12 foot long
headlamp bezels and tops of wings look good, steps are there but i dont know how much longer the passenger one will be, did i mention the awful bonnet ??? .... started on three for about a second then went onto four...
oil is spotless...
decisions decisions
whats a camper worth these days???
3 piece prop with no discernable pay in it, although the diff feels as loose as a nuns habit (twistin the prop back an forth about 1/4 of a turn)
rear step has been shunted in where h let it roll into his house which has affected how the back door closes... rear lights look like VW lt ones mounted upright like mk1 tranny ones.. (lights in roof as well red only though)
looks like suspension shock absorber mount on o/s has either been coated with fibreglass or welded and plastered with seam sealer.... wasnt prepared to dig it out with him watching....
step bits under the doors are a bit mishappen like they was folded using a hammer and a block of wood but I know these are availalbe anyways...
rottie_007
Postby madmark » Sun Nov 20, 2005 4:50 pm
mate why do you think it needs a prop????? the rear axles always have 1/4 play in them ,i had mine rebilt and it still clonks now and again! why no coolant in the engine???? was it drained or has it got a core plug gone?????? :?and you say discs???????
he told me it
Postby rottie_007 » Sun Nov 20, 2005 5:08 pm
he told me it needed a uj doing..
an yeah shes got discs......
lack of coolant is a mystery...
and one that puts me off a bit to be honest
although the rad looked like it had white fluff in it...
the oil was spotless s owould be surprised if it had gone the oil-route
the underside looked like it had been regularly oiled...
probably by the gearbox or diff....
im in two minds about whether to or not...
rottie_007
Postby Luke » Sun Nov 20, 2005 5:12 pm
why can't you just fill it up and see if and where it comes out!!
:D
cause all I
Postby rottie_007 » Sun Nov 20, 2005 5:13 pm
well luke...
1 i was in brom
2 all I had or he had was plain water
3 I didnt want to fill it up only to find it hydrauliced and then he go into once cause "you broke me van"
rottie_007
on a positive note
Postby rottie_007 » Sun Nov 20, 2005 5:22 pm
I was doing a bit of searching on google and found this....
http://www.aquarod.co.uk/newweb2Y.jpg
this is definitly the same bus....
I guesss the wilsons of london plate I found was the supplier not the coachworks...
so she is a Jennings mk1 road ranger
rottie_007
Return to Mk 1 & 2
