wheel cylinder clips
Postby Gunslinger » Fri Dec 30, 2005 10:13 pm
ok, sorted the lockheed ones were better, grooves deeper and cleaner cut, clips were fiddley as hell ... but eventually went on (as you said Nighthawk, help was much appreciated thx)
i still wanna know how your supposed to do that on the vehicle :lol:
Gunslinger
Postby Nighthawk » Sun Jan 15, 2006 5:18 pm
Glad you sorted it.
On the vehicle you have to try and wedge your head between the chassis rail and the spring while you hold 2 screw drivers with your knee on the wheel cylcinder.
:lol: :lol:
I prefer doing it with thebacplate on the bench though :D
Nighthawk
Postby Gunslinger » Sun Jan 15, 2006 8:59 pm
yeah, you could hold the whole lot in a vice that way :P
it has got to be one of the most stupid designs i have EVER seen, i think i might still pick up some spare wheel cylinders sometime and thread the outside of the brake pipe fitting turret, that way i wont have to f**k around like that again :P (something else i have to take into account is i am not having rigid pipes back there as the whole back axle is being done with aeroquip hosing except the rubber link to the vehicle)
Gunslinger
Postby Nighthawk » Tue Jan 17, 2006 7:05 pm
Gunslinger wrote:yeah, you could hold the whole lot in a vice that way :P
You should try going one on a sunday morning as a moneymaker and you find out that the little locating dowel has been put slightly out of place :twisted: :twisted: having to open up the holes in the backplate or redrill the pin is a right PITA.
Still, it was fun while we used them, but the upgrade to bolted cylinders in 8/91 was a much better idea :D
Nighthawk
Return to Mk 1 & 2
