cost about £300 way back then ,cant remeber what i done with it tho,it also fitted the 4 speed type f box i used it for a wile then went auto !
V8TRANSIT wrote:i run a 3.0v6 overdrive box and zephyr diff its perfect in my mk1, the v6 has plenty of torque to put it 120+ even though its only got 150hp. this is a very good setup if you can sorce the parts
FredTransit wrote:The Mk2 had the OD box. It's basically the same box as the 4 speed with an OD unit bolted to it.
