Mk3 Steering on Mk2
Re: Mk3 Steering on Mk2
Postby Gunslinger » Sun Oct 05, 2008 3:01 pm
cyberchild wrote:eeh... I did not use the mk3 kingpin. Did not have the right tools. But then i tried mk2-mk3 swap, i just used the front hub 6studs from a mk3. fitted just fine. become a little bit wider at the front, but thats ok. A little misunderstanding from ford dealer makes me on a hold. waiting for the right bits and parts...
so what you are saying is that the mk3 front hub extenders, that bolt to the disks are bigger (stick out further) than on a mk2 ? which disks a calipers did you use ?
Gunslinger
Return to Mk 1 & 2
