mk1/2 rear axle
Re: mk1/2 rear axle
Postby Rolo » Wed Mar 22, 2006 1:30 am
tb2 wrote:hi
will a mk1 twin wheeler rear axle fit a mk2 twin wheeler thank you for any help in this matter ian
At some stage I was led to believe that one other difference is that the brake shoes in the Mark 2 are wider and if anybody can either confirm or deny this it would be of help because I'm in the same predicament myself, trying to change to the best axle I can in my Mark 1.
1973 drw; Falcon 250 c.i.; 12v fuel pump; belt-driven water pump & fan replaced with 12v water pump & two 12" fans; T5 gearbox; Mark II front discs.
Rolo
Return to Mk 1 & 2
