madmark wrote:mate you have trico these would have been orginal type to the van! you should have a clip at the end this you sqeeze together and the rubber and blade should come out of the metal frame!
take the clip off and slide out the rubber![]()
now getting replacement rubber is going to be very hard to find as most replacement rubbers are not wide enouph to sit in that frame!
i will keep an eye out ,for you!
madmark wrote:the problem is these wipers are getting very hard to find!
black ones are not to bad but original chrome are hard to get!
there is a good chance if you get stuck i will find you a pair but these will be £40 and you might need to hang on till end of march!
