mk2 fuel/injection pump woes
Postby oooeee » Fri Mar 17, 2006 1:50 pm
Cheers Fred,so do i take it that its a 2.5 and not 2.4 then????
OOOEEE
Full Of Rusty Dents My Arse!!!!!!!!!!
oooeee
Postby TRANSITBILL » Fri Mar 17, 2006 2:01 pm
:D :D :D :D :D Hi thats an early di, i personally think it was the best di as no vac pump on rear of alt to keep packing up,mind you if the vac pump belt goes you get a sevo full of oil lol :) :lol: :) :lol: :) :lol: :P .............. any road if it had been a yorkie with 4 glow plugs they are in the inlet manifold i seem to remember 3 in one out ,been a while since i worked on a yorkie ,even longer for a 3.5 yorkie in an a series transit best wishes Billy ....... :D :D :D :D :D :D :D :D :D :D :D :D :D :D
TRANSITBILL
Postby oooeee » Fri Mar 17, 2006 2:10 pm
Cheers Billy :D you guys have been a real help on this for me.Finding this forum has stopped me from throwing in the towel on the old girl. Looks like i'm on a pump hunt then eh :!: If anyone knows of one i'd be really grateful. :wink:
OOOEEE
oooeee
Postby FredTransit » Fri Mar 17, 2006 2:21 pm
It's not an early Di, the early ones have a Lucas CAV pump.
FredTransit
Mk2 Trannyist
Postby oooeee » Fri Mar 17, 2006 2:31 pm
Maybe mine was supposed to have as its got a lucas filter housing on it.
OOOEEE
oooeee
Postby oooeee » Fri Mar 17, 2006 2:34 pm
If i get the number off the block that will surely help me pin it down yeah?
OOOEEE
oooeee
Postby gemini » Fri Mar 17, 2006 2:55 pm
i think it has the wrong pump, it should be a lucas, ford did fit some earlier di's with bosch pumps on the 190 twin wheelers
gemini
Postby MrMPuk » Fri Mar 17, 2006 2:57 pm
Isn't the date on the block on the right hand side near the front under where the oil filer cap is?
Postby oooeee » Fri Mar 17, 2006 3:23 pm
Cant find any numbers at all on the right hand side of block but on the left i found 844F-6015-CA with a larger number 2 underneath it. Also there's a number on the air intake 844F-942 AC 016865.
OOOEEE
oooeee
Postby gemini » Fri Mar 17, 2006 3:31 pm
they will just be casting numbers, the date is on the cylinder head at the front of the oil filler
gemini
Postby oooeee » Fri Mar 17, 2006 4:10 pm
It's bloody cold out there!!!!!! Right there's 84 on there so i take it that means di.
OOOEEE
oooeee
Postby TRANSITBILL » Fri Mar 17, 2006 8:43 pm
:D :D :D Hi it has to be an early di as the vacum pump is built in on lower left looking at engine and the alt is fastened top left,i have the same engine same pump,filter housing on mk 2 b redg it has the orignal engine still in best wishes billy :D :D :D ..the pump has a cable cold start devise same as mine bit similiar to the later lucas cav pumps :D
TRANSITBILL
Return to Mk 1 & 2
