I was talking to a chap the other day who said he bolted turbo gear onto a 76ps and didnt change the pump or injectors at all
Ive already started stripping the donor van now, decided i couldnt wait till wednesday
Retrohowla wrote:Yes the injectors are blue spot, i am lead to believe you can use 85 ps injectors and it will run ok but not as powerfull as if you use 100ps injectors.
I was talking to a chap the other day who said he bolted turbo gear onto a 76ps and didnt change the pump or injectors at allHe seemed to think it ran ok and was allot better on hills than the standard 76ps di.
Ive already started stripping the donor van now, decided i couldnt wait till wednesdaythe motor is ready to lift out in the morning
Retrohowla wrote:Ok guys, the bosch pump is fitted to the 100ps motor now![]()
What do you recomend i set the pump timing to?
Was thinking bang in the middle then work from there once its in the van and can be started![]()
Some hints here would be great, the project is coming along sweet though![]()
alanwh wrote:Most difficult bit is going to be routing the piping as it will probably have to to go out and back from the nearside of the radiator to a crossflow type intercooler.The turbo on the DI exits top end too which is a bummer as it makes things doubly awkward.
Don't be tempted by an intercooler with inlet and outlet at the same end, they are crap
