Laycock overdrive
Re: Laycock overdrive
Postby jpv » Mon Jun 15, 2009 10:55 am
What about a diesel york engine? what bellhousing and input shaft is needed?
jpv
Postby madmark » Mon Jun 15, 2009 2:22 pm
a di gearbox will fit to the york engine! :wink:
Postby sim » Mon Jun 15, 2009 3:49 pm
Just looked at this subject .I have a overdrive on my essex v6 mk2 and it seems there are 2 types ,fixed spline and reverse spline. Mine is the same as madmarks (fixed spline). looking at madmarks nice clean chassi I wondered ,do you have a one piece prop or the split system(mines split system). If it is a one piece, do you find any difference in smoother gear changes.Im glad to have the overdrive as first gear is almost pointless and it helps on the mpg
sim
Postby madmark » Mon Jun 15, 2009 5:48 pm
hi my set up will be the same as yors as it came from a v6 petrol transit 1987 :wink: :wink:
Return to Mk 1 & 2
