Adaptor plate for MT75 Gearbox to Essex V4/V6 Interest?
Re: Adaptor plate for MT75 Gearbox to Essex V4/V6 Interest?
Postby dieselhead123 » Thu Feb 21, 2013 9:51 am
Maros - OLDFORDCLUB wrote:
Hi TIM
I sent to you PM about adaptor. I need one unit for my Mk2 3.0Essex v6, including bearing and bolts. Tell me if is possible help me with it. I am from Slovakia.
Hi mate, I have sent you a pm.
Postby MinorMatt » Thu Feb 21, 2013 11:51 am
If you arn't in a hurry Nadjenka normally goes back to Slovakia once or twice a year... I'm sure that would cut down on the carriage costs?
Postby Maros - OLDFORDCLUB » Thu Feb 21, 2013 8:28 pm
MinorMatt wrote:If you arn't in a hurry Nadjenka normally goes back to Slovakia once or twice a year... I'm sure that would cut down on the carriage costs?
Hi MinorMatt. Sorry, but dont now who is Nadjenka. Maybe someone from forum?
Maros - OLDFORDCLUB
Postby Leeday » Wed Sep 25, 2013 12:32 am
Great thread 8)
1989 Mk3 swb, 3.0 V6 Essex, 5 Speed Manual: http://fordtransit.org/forum/viewtopic. ... 3&t=142054
2005 Mk6 2.0 Duratorq 100 T350 MWB Semi High
Leeday
Postby disco_monkey79 » Fri May 20, 2016 5:08 pm
Hi
Apologies if this has already been discussed and I missed it, but...
Can anyone tell me what the MT75 gearbox ratios are? I presume from the happy comments that the Essex gets on well with them?
disco_monkey79
Postby robbie.cee » Fri Jun 03, 2016 1:13 pm
Can't help with ratios but my Essex v6 drove great with mt75 box and suddenly could do double speeds in each gear too! Great motors
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby tonypastie1 » Fri Sep 02, 2016 10:54 pm
Would this adaptor plate allow
Mtx gearbox from a di transit to fit v6 cosworth or
Is that differant again ?
tonypastie1
Postby dieselhead123 » Sat Sep 03, 2016 9:20 am
tonypastie1 wrote:Would this adaptor plate allow
The Cosworth V6 we had in the Granada in the UK was based on the Cologne engine so has a different bellhousing pattern to the Essex, if you have one of these then best to look out for the SVO adapter kit used with the 2.9 fitted in the Mk3 Transit. You will need the adapter plate, flywheel and starter.
If you are lucky enough to have one of the Cosworth GAA quad cam engines, (based on the Essex block), then this will fit to the Mt75 di gearbox using our adapter plate.
PS Nice Fire van 8)
Postby tonypastie1 » Sat Sep 03, 2016 9:42 am
Thanks for the info Tim!
tonypastie1
Postby disco_monkey79 » Wed Jun 07, 2017 1:40 pm
Has anyone fitted an Essex to a diesel van, or are you doing this to Pinto-engined vans, and using the diesel gearboxes?
If a diesel-motored van has been done, then how much of a pain was it to sort the wiring? And can anyone give any pointers?
Many thanks
disco_monkey79
Postby DodgeRover » Thu Jun 08, 2017 9:17 am
Should be straight forwards wiring as the essex is an old lump it will only need a continuous live to the coil for it to spark. Starter, alternator etc will all be the same but may be positioned differently.
DodgeRover
Postby greentransit » Fri Nov 22, 2019 1:53 am
dieselhead123 are you still getting these made as i need to convert my mk3 from type 9 to mt75 ;-)
Mk3 massive member
1988 190 mk3 3.0v6
1990 190 mk3 2.9v6 svo
1991 160 mk3 2.5di
greentransit
Postby dieselhead123 » Fri Nov 22, 2019 8:38 pm
greentransit wrote:dieselhead123 are you still getting these made as i need to convert my mk3 from type 9 to mt75 ;-)
Just completed some more adapter plates, so 'yes', now available again.
What engine are you running in your Mk3?
Postby greentransit » Tue Dec 03, 2019 2:06 am
just seen your reply ill pm you :-)
Mk3 massive member
1988 190 mk3 3.0v6
1991 160 mk3 2.5di
greentransit
Postby paul sutton » Thu Jan 02, 2020 2:03 am
[quote="greentransit"]
hi can you give me the price for the v6 adaptor plate to 2.5 di engine,thanks paul]
paul sutton
Return to Mk 1 & 2
