Adaptor plate for MT75 Gearbox to Essex V4/V6 Interest?
Re: Adaptor plate for MT75 Gearbox to Essex V4/V6 Interest?
Postby dieselhead123 » Thu Jan 02, 2020 8:02 pm
paul sutton wrote:
greentransit wrote: hi can you give me the price for the v6 adaptor plate to 2.5 di engine,thanks paul]
Hello Paul, the complete kit is priced at £195 plus postage. Parts are in stock.
This kit enables the Di Mt75 gearbox to be mounted to either the Essex V4 or V6 engine.
The kit comprises of the adapter plate, all the fixing bolts to secure it to the engine, a spacer for the clutch pivot and a new spigot bearing.
This kit uses the stock Essex clutch and flywheel used with the Essex engine.
Postby Greg L. » Mon Jan 06, 2020 7:07 am
Would it be hard to produce a MT75 + V4/V6 Cologne adapter plate ?
Greg L.
Postby dieselhead123 » Tue Jan 07, 2020 11:17 am
Greg L. wrote:Would it be hard to produce a MT75 + V4/V6 Cologne adapter plate ?
Fairly straight forward job to do, we didn't bother doing these as there are some original Ford SVO kits about and did not think there would be much of a market for 'copies'.
The Ford kit comprises an adapter plate as well as a bespoke starter and flywheel, SVO engine mounts are also available.
If you wanted to fit a Cologne to a Di type Mt75 then you are best off looking for one of these SVO kits. There was one listed on UK ebay a short while ago, so might be worth a search.
Postby OkurkaSalatova » Sun Dec 20, 2020 9:51 pm
Hello
does anybody fitted mt75 in to mk1 V4 1.7 with two wheels in back (firetruck)? Is it possible with this kit? If so, how the car worked?
Thanks, Ondrej
OkurkaSalatova
Postby dieselhead123 » Sun Dec 27, 2020 12:17 pm
Hi there, the kit was developed so it could be used behind any of the Essex V engines and would provide you with n overdrive 5th gear. When using it as a replacement for a 4 speed gearbox you would need to reposition the gear lever in the cab floor and alter the prop shaft. The kits are available from ourselves, PM if you would like further information.
Postby Gavbell88 » Wed Jan 04, 2023 8:16 am
I’d be interested in one of these kits if you could pm me details please or Chuck me a email over gavbell54@gmail.com
Gavbell88
Return to Mk 1 & 2
