Mk2 pinto to early di conversion
Postby Luke » Sat Jul 07, 2007 11:35 pm
Retrohowla wrote:engine go straight on pinto mounts?
yep
Retrohowla wrote: gbox x-member bolt straight in or do i need to redrill of fabricate new mount?
see post above :lol:
Retrohowla wrote:it your brain frying yet cos mine is!! :?
nope :lol: ive done this conversion few times before :lol:
Postby Retrohowla » Sat Jul 07, 2007 11:36 pm
Ah yes premature i am, so i need to modd x-member, yes i have a welder, not a mickey mouse job either, capable of decent penetration and integrity
If you own a transit, learn to weld
Retrohowla
Postby Luke » Sat Jul 07, 2007 11:38 pm
Retrohowla wrote:Ah yes premature i am, so i need to modd x-member, yes i have a welder, not a mickey mouse job either, capable of decent penetration and integrity
then you will be fine 8) its easy to mod - just the mounting brackets need adjusting :D
Postby Retrohowla » Sat Jul 07, 2007 11:38 pm
Good good, dont spose you have any snaps of modded x-member do you?
Retrohowla
Postby Luke » Sat Jul 07, 2007 11:39 pm
Retrohowla wrote:Good good, dont spose you have any snaps of modded x-member do you?
im afraid not :( but tbh its fairly obvious when you see both of them together :D
Postby Retrohowla » Sat Jul 07, 2007 11:40 pm
righto i seem to be getting somewhere in my head now
is my plan for the prop sensible or do you recomend a different option?
Retrohowla
Postby Luke » Sat Jul 07, 2007 11:44 pm
prop - as your going swb to lwb - right yeah? you'll not beable to shorten it but according to info on here the mk3 lwb prop is the same lenght as the mk2 so a mk3 mt75 (1989-1986) should fit ok other than that you'll need any later lwb prop and shorten it :)
or lengthen your swb one but i dont think they are thick enought to take the extra length :?
Postby Retrohowla » Sat Jul 07, 2007 11:48 pm
What about weld the flanged u-j from the mk4 prop onto the mk2 prop?
mk2 prop the correct length just spline instead of flange isnt it?
Retrohowla
Postby Luke » Sat Jul 07, 2007 11:51 pm
Retrohowla wrote:What about weld the flanged u-j from the mk4 prop onto the mk2 prop?
mabe :? - the mk2 prop slides in and out of the front splines (in the gearbox), the mt75 has a sliding part on the prop - mines at the back - there are plenty of different ones - you could mabe make one out of the 2 but it will need the slider on it to take into account the axle movenent :D
Postby Retrohowla » Sat Jul 07, 2007 11:57 pm
Copy that, i think mine on the mk4 slides in the middel, so i can use the drive end uj from this one to replace the drive end uj from the mk2 prop?
i am guessing now just got a picture in my head and trying to imagine how i could do it
either that or ant good sources for a mk3 lwb mt75 prop?
Retrohowla
Postby Retrohowla » Sun Jul 08, 2007 12:00 am
no scrap that cos the drive end is shorter on the swb and to keep the slider you need it right up to the center bearing so thats that out
so new prop it is
Retrohowla
Postby Luke » Sun Jul 08, 2007 12:02 am
try a wanted add on here :D
is the mk2 a daily driver :?:
Postby Retrohowla » Sun Jul 08, 2007 12:03 am
No i have another car but want to try and turn her around quick as got allot of miles to do in her from the 26th on
pushing it i know
Retrohowla
Postby Retrohowla » Mon Jul 09, 2007 12:13 pm
Hi Luke, found a guy who has a a few old props in his yard but none have been labeled so he cant tell me what they came off, all he knows is there should be at least a couple of mk3 ones there
Can you tell me what length the mk3 prop should be please do do my conversion?
this way i can just go down with a tape and pick one up rather than do the build and then measure the gap!
Retrohowla
Postby Luke » Mon Jul 09, 2007 11:27 pm
Retrohowla wrote:Can you tell me what length the mk3 prop should be please do do my conversion?
i'm not sure :? someone else might know :D
Return to Mk 1 & 2
