Fred- Mk1 camper wrote:Pretty sure cylinders are right. Same in size and bore as ones that came out.
Just done the ‘press the pedal’, ‘let go’ exercise again maybe 20 times each side with engine running. Some resistance but shoes don’t go anywhere.
Can’t figure it out???
Pablo-pilot wrote:Hello! New brakes are a good thing. However, I would advise you to attach the cylinders not to the locking ring, but not to be lazy and cut threads into them and put them on bolts!
Ralph.9 wrote:That back plate is in the wrong orientation, the cylinder should be at the top & the cable enter from the front.
