Late bosch pump into mk2 turbo conversion
Re: Late bosch pump into mk2 turbo conversion
Postby Retrohowla » Sun May 31, 2009 4:07 pm
Any ideas what this little hose tail is for on the side of my bosch 145?
The pump came with no pipework so im just trying to work out what goes where
If you own a transit, learn to weld
Retrohowla
Postby MinorMatt » Sun May 31, 2009 9:05 pm
Just left like that on my N/A van nothing on it at all
Postby alanwh » Sun May 31, 2009 9:06 pm
Its a pressure relief valve :D
alanwh
Postby Retrohowla » Mon Jun 01, 2009 1:13 pm
Ok cheers guys, so no need to plumb it in to anywhere then?
Retrohowla
Postby alanwh » Mon Jun 01, 2009 7:29 pm
Nope :D
alanwh
Postby godderidge » Mon Jun 01, 2009 11:28 pm
I have a mk 5 turbo intercooled with a 146 pump and am in Eastleigh If you want to have a look you are welcome
godderidge
Postby redeemer » Tue Jun 02, 2009 8:24 am
Could you take a pic of the setup, especialy the inter cooler...?
How it goes, will it try to fly? :P :P :mrgreen:
1982 MK2 SWB 2.5 DI 5 SPEED 70PS now with turbo
1982 MK2 LWB PICKUP 2.5 DI 4 SPEED
redeemer
Postby Retrohowla » Tue Jun 02, 2009 10:02 pm
godderidge wrote:I have a mk 5 turbo intercooled with a 146 pump and am in Eastleigh If you want to have a look you are welcome
That might be very helpfull :D
When my motor is in the van if i get stuck i may come and have a butchers, cheers :D
Retrohowla
Postby alanwh » Wed Jun 03, 2009 11:04 am
Don't forget some lovely photo's guys of the intercooler arrangement :D :D :D
alanwh
Postby Retrohowla » Wed Jun 03, 2009 12:24 pm
If i take a butchers i will be sure to take some snaps, if im allowed of course
Retrohowla
Postby Retrohowla » Wed Jun 03, 2009 9:03 pm
Right the turbo lump is bolted into the mk2 now 8)
Not finished plumbing it in yet so hopefully will give her a crank by lunchtime tomorrow and see what happens, hopefully it makes all the right noises :D
Retrohowla
Postby Retrohowla » Thu Jun 04, 2009 5:31 pm
Ok she lives :!: 8) 8)
Been for a spin and she pulls ok but not as well as i would hope, ive fiddled with pump timing slightly and it made it better but still not ideal.
Fully advanced made it very loud and clacky and slower, seems to prefer roughly the spot on the timing holes.
Is it time to fiddle with the fuelling of do i need to get someone in the know to cast thier eye over this pump timing?
Retrohowla
Postby redeemer » Thu Jun 04, 2009 6:11 pm
Have you played with the fueling of the pump?
And have you checked the boost pressure of the turbo?
And checking the tappets would do no harm either.
redeemer
Postby Retrohowla » Thu Jun 04, 2009 6:29 pm
Ok so i got twitchy and turned the pump up, a half turn at a time till i got to 2 full turns, she now flies, well compared to what it was anyways.
Im not sure if i have set it up right though, its quiet, starts easily and pulls well through the gears.
I cant see even a puff of smoke though so maybe it needs turning up more???
Your thoughts guys are most welcome
Retrohowla
Postby Retrohowla » Thu Jun 04, 2009 6:31 pm
Bosst gauge is to be fitted tomorrow, bleed off valve after that, tappets are within tollerance, btw redeemer, do you still need a bosch 145?
Retrohowla
Return to Mk 1 & 2
cron
