MK 3 axle
Postby Gunslinger » Fri Apr 07, 2006 9:36 am
by all means you can say that, just dont complain to us when you buy one and find its slower, got less pulling power, locks the rear wheels at the slightest opportunity, seems to have been built from second grade plastic everywhere, generally starts falling to pieces inside, and the only way you'll get one with good rear doors is to buy a new one :P
that said, they do make a good source for donor parts for a transit :lol: ... mine has the rivet in side windows from an LDV 400 and the spare wheel carrier from one mounted under the rear end :D
and i guess you could argue they are cheaper for spares as there are soooooo many of them in the breakers yards :twisted:
Gunslinger
Postby daddy cool » Fri Apr 07, 2006 10:59 am
That's a much better argument than mine GS. :wink:
I was just going to say they're pig ugly in the flesh :oops:
Even if you don't need it, grab it.
The minute you do need it, it'll be gone.
daddy cool
Postby snakemaster » Sat Apr 08, 2006 3:06 pm
Those Leyland buses look smarter than Transits.
:D they are made from papermashy and plastic fire gards the crapest of the crap but still beter than some transits (not meny) am i aloud to say that , Those Leyland buses look smarter than Transits. i dont no what transits you have seen? :o :P :evil: O well some people will never learn
Rolo have you got some crapy pics of vans from OZ non ford ? you would like to post so we can get a laff
Wanted manta A front spoiler , i now theres one out ther for me
snakemaster
Postby FredTransit » Sat Apr 08, 2006 3:33 pm
Rolo wrote:Thanks.
Am I allowed to say that in this forum? :)
No.
FredTransit
Mk2 Trannyist
Postby Gunslinger » Sun Apr 09, 2006 9:44 pm
oh dear .... fred's getting the whip out again ;)
Gunslinger
Postby 100ps_drw_hicube » Sun Apr 09, 2006 10:04 pm
daddy cool wrote:That's a much better argument than mine GS. :wink:
and there suspension is non existent :lol: :lol: a real back breaker if you go over the slightest of bumps and dont buy a hi top there roofs are c**p i went thru one once :oops: yet saying that i can walk on my roof ok :lol:
100ps_drw_hicube
Transit Abuser!!
Postby snakemaster » Thu Apr 13, 2006 8:18 pm
Hey we have sort of lost the axle thread has any body got any more info on axles and what can be swaped over :lol:
snakemaster
Postby Rolo » Fri Apr 14, 2006 3:20 am
snakemaster wrote:Hey we have sort of lost the axle thread :lol:
Not necessarily.
Somebody could very well tell us anytime soon which Leyland van has an axle that will fit a Transit. ;)
1973 drw; Falcon 250 c.i.; 12v fuel pump; belt-driven water pump & fan replaced with 12v water pump & two 12" fans; T5 gearbox; Mark II front discs.
Rolo
Postby Sundowner » Fri Apr 14, 2006 3:36 am
Rolo
A friend of mine has a mk1 twin wheel and has had a 2.78 falcon center fitted
They just cut the axle tubes off the transit diff and weld them to the falc center
Sundowner
Postby Rolo » Fri Apr 14, 2006 3:57 am
Sundowner wrote:Rolo
I was told those jobs are nowhere near as strong as original Transit axles (something to do with 2 and 4 "spiders"? as well) and wear out very quickly, they charge a lot of money for those conversions and keep in mind my Transit is a 3 ton camper and that's the minimum weight it carries all the time.
Rolo
Postby Sundowner » Fri Apr 14, 2006 4:21 am
The 4 pinion falcon diff will take 600 odd hp so it wont matter if your van weighs 10 ton your engine will never have enough power to hurt it
As for the method used to join the tubes to the housing it is the same as ford use with the transit housing and the factory transit axles are still used
You also have a choice of ratios from 2.78 to 4.11
My friends diff cost $1200
Sundowner
Postby Rolo » Fri Apr 14, 2006 8:45 am
Sundowner wrote:My friends diff cost $1200
With or without a limited slip diff? :o
Rolo
Postby Rolo » Fri Apr 14, 2006 8:51 am
Sundowner wrote:The 4 pinion falcon diff
"4 pinion"?
I thought all diffs had just one pinion and crown.
Is that the one they call a 9" diff?
Rolo
Postby Sundowner » Fri Apr 14, 2006 10:03 am
without LSD
no diffs are either 2 or 4 pinion, not the main drive pinion gear but the so called "spider" gears
Like if you where to pick up your factory ford transit repair manual and look up the decription for the 175 diff it will say that its a 4 pinion split differential case
The Borg Warner or BTR 78 series diff found in every thing from xy falcs to the current model BF ute is the diff im talking about
the later diffs are extremly strong
a 9" will take 1000+ hp
Sundowner
Postby Rolo » Mon Apr 17, 2006 5:57 am
Is an engineer's certificate needed to make those alterations?
Rolo
Return to Mk 1 & 2
