Electirical Question for the experts - please
Re: Electirical Question for the experts - please
Postby AmbulanceMan » Wed Aug 05, 2009 4:02 pm
GBBiker wrote:I have the Banana Di and I rarely see the needle move at all.
The only time the needle moves up the gauge tends to be when I'm stuck in traffic.
If you read my above post, I did a test dropping the wired up sender into some just boiled water. Do you think that should move the needle? I just don't know. Maybe this thing is working perfectly and my engine just won't overheat, but then again, the just boiled water is pretty hot, but water in the engine, under pressure would be hotter, right???
AmbulanceMan
Postby Luke » Wed Aug 05, 2009 4:49 pm
is yours is a single wire sender :?: if so did you earth the water :?: if not no :!:
:D
Postby GBBiker » Wed Aug 05, 2009 5:30 pm
In boiling water, the needle should definately move. The gauges range from about 60 degrees at the lower end of the scale up to about 110 degrees.
GBBiker
Wrong Again!
Postby AmbulanceMan » Thu Aug 06, 2009 9:53 am
:D
It is a single wire unit which also has a ground wire, if that makes sense.
Yeah, I guess I kinda did earth the water. I connected a wire to the body of the sender and earthed that, but as it ended up in the water I guess it earthed the water as well.
The sender wire bit was in the water as well though. I just wired it up, with ground wire included, and dipped it in the hot water. Did I get it wrong?
AmbulanceMan
Postby AmbulanceMan » Thu Aug 06, 2009 9:56 am
GBBiker wrote:In boiling water, the needle should definately move. The gauges range from about 60 degrees at the lower end of the scale up to about 110 degrees.
Thanks for that.
AmbulanceMan
Postby rottie_007 » Mon Aug 31, 2009 7:14 pm
hi ambulance man, slightly off topic and I apologise for that BUT can you take a photo of your engine in your engine bay as im about to banana my mk2 and would like a rough idea of how it will all look when installed !!!
you can email it direct to ratdax@googlemail.com if you doint like putting pics on a forum?
1979 mk2 pre facelift CI campervan " Bessie Brown "
1994 Pug 405 est " George "
1998 pug 106 "Mildred"
rottie_007
Postby manandvan » Sat Sep 05, 2009 9:13 pm
seems everyone missed the most obvious one here?? when you go to the motor factors buy a new thermostat for it, i would guess the old one is probably stuck open or even missing :D
manandvan
Return to Mk 1 & 2
