Adaptor plate for MT75 Gearbox to Essex V4/V6 Interest?
Re: Adaptor plate for MT75 Gearbox to Essex V4/V6 Interest?
Postby Ken B » Wed May 23, 2012 4:33 am
No Worries but please don't blame me if it don't work. I can only go by the book and google!!! :wink:
Ken B
Location: Spalding lincs. The land that time has forgotton.
Postby dieselhead123 » Fri Jun 01, 2012 7:42 pm
Finally got round to catching up with the adapter plate mods!
Another plate had been produced, to correct the few small errors in my measuring and allow for the starter motor to be re-positioned so as to utilise an existing bell housing fixing for one of the starter motor mountings.
The starter fitted to the plate on the Mt75 gearbox,
A small amount of material will need to be removed from the bell housing of the Mt75 gearbox to allow for starter motor clearance.
I cut mine out with an air belt sander, slowly, to establish exactly how much material had to be removed, but for those of you that choose to utilise this conversion, an angle grinder will suffice. This would be quite easy to accomplish even if the gearbox were still in the vehicle.
In an ideal world I would re-weld the bell housing case, but a small metal plate and a large amount of sealant will no doubt suffice.
I hope to find time to get the engine fully fitted to the gearbox over the forthcoming weekend, watch this space!
Tim
Postby montym100 » Sun Jun 03, 2012 1:58 pm
Good work, fingers crossed the stock clutch and thrust bearing work out.
montym100
Postby pete.tv » Mon Jun 04, 2012 7:59 pm
hi guys,conversion looks good, i"m interested .being a bit dumb on mechanics side would be greatto know about speedo cable.
thanks keep up the good work.
pete.tv
Postby Luke » Mon Jun 04, 2012 8:11 pm
pete.tv wrote:hi guys,conversion looks good, i"m interested .being a bit dumb on mechanics side would be great to know about speedo cable.
speedo cables no problem mate - just use an MT75 with a cable and the end that plugs into the speedo cluster is the same on the mk1/2/3/4/5
Postby robbie.cee » Mon Jun 04, 2012 8:33 pm
Essex boy ere when can i fit my Essex? :lol: :wink:
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby dieselhead123 » Mon Jun 25, 2012 6:49 pm
robbie.cee wrote:Essex boy ere when can i fit my Essex? :lol: :wink:
No long now mate 8)
Postby dieselhead123 » Mon Jun 25, 2012 7:32 pm
Finally, after lots of 'head scratching', and a few bits of scrap metal, we have a 'working' Mt75/Essex adapter plate :D
Information on how to fit the plate to the rear of your Essex engine is as follows;
Remove your existing clutch and flywheel,
Remove the tin plate fitted to the rear of your engine,
The rear of your engine should now look like this,
Fit the adapter plate, tapping it firmly onto the dowels that protrude from the rear of your engine,
Insert and secure the fixings provided, there are four countersunk fittings, two each 3/8 and 5/16 unc, make sure these are fitted in the correct holes,
Install the hex head bolts in the remaining holes,
Install the custom spigot bearing supplied,
Re-fit your flywheel, the head of one of the countersunk fixings can just be seen,
The next post will detail clutch selection and fitting.
Postby Ken B » Mon Jun 25, 2012 8:56 pm
Very nice. Well done.
Ken B
Postby robbie.cee » Mon Jun 25, 2012 9:28 pm
Nice work Tim! very nice!!! :wink:
Had
MAKE IT FIT
robbie.cee
Postby dieselhead123 » Mon Jun 25, 2012 9:33 pm
robbie.cee wrote:Nice work Tim! very nice!!! :wink:
And since I now have a V6 flywheel, you can have yours back.
Thanks for the loan of it mate, without it, I would not of got this far as soon :lol:
Postby montym100 » Tue Jun 26, 2012 9:18 pm
Thats looking great :wink:
Any ideas on the cost of the kit when it`s available?
montym100
Postby Highlander250469 » Tue Jun 26, 2012 9:36 pm
If its any use I can quickly create STL and GIO files from scale pictures or drawings.
eg if someone makes an adaptor plate by hand I can either use a picture of it or an outline tracing to create cutting files.
Highlander250469
Postby Parcel » Tue Jun 26, 2012 9:50 pm
And I can do .dxf files and polyline them, if needed........and probably print them 1:1 on paper if they need checking...
Parcel
Postby dieselhead123 » Thu Jun 28, 2012 8:34 am
montym100 wrote:Any ideas on the cost of the kit when it`s available?
Right then lads, since the development of the adapter plate is all but complete, this may well be the appropriate time to put a price to it.
As you all no doubt appreciate, a great deal of time, effort and £s have been put into the development of what I would consider to be a precise piece of engineering. I do however recognise the support and assistance of other Forum members, without whom this project would have been more difficult to complete.
I set out to produce something never before done and believe that I have achieved it.
The intention is to provide a 'modular' product, where the adapter plate (and associated fittings), can be purchased as a basic 'kit', this will suit those of you wishing to fit the Mt75 gearbox to the rear of your existing V4/6 Essex engine, to replace the existing 4 speed gearbox.
Engine mountings, power steering pump brackets, exhausts etc, (for Mk3/4/5), will be sold as 'add-ons' for those wishing to install an Essex V6 in place of their 2.5di engine.
The adapter plate, securing bolts and spigot bearing will be £175 to Forum members. Postage will be charged at cost, we are happy to 'ship' anywhere in the world. Collection from our works or from myself at any of the meetings/shows I attend would also be possible.
The pricing of the 'add-ons' to install the engine into Mk3/4/5 vehicles has yet to be finalised.
A 'build' thread will be put together and posted on the Forum to assist those who make the purchase install the parts and as always we will be available to be contacted on the works number should any of you require further assistance.
Return to Mk 1 & 2
