mk2 power steering?
Re: mk2 power steering?
Postby mb4ever » Sat May 11, 2013 3:20 pm
Vandalism wrote:ive heard you can use vauxhall corsa b electronic power steering
viewtopic.php?f=23&t=92439&hilit=+power+steering
Do you know the life expectancy of the Corsa pump used like that please Vandalism?
Quote "I[i] have looked into the corsa pump's and apparently failure of the pump is quite a common occurance, In fact i have read quite a few articles as regards to electric pumps packing up..[/i]
"http://www.pistonheads.com/gassing/topic.asp?t=1260691
I've heard that about electric power steering pumps too.
On the other hand, does anyone know of a reason why one can't use a belt drive pump instead of the electric one.
mb4ever
Postby jonochap » Sat May 11, 2013 3:26 pm
There is someone on here that may know some of this...im sure i have seen this posted before ;)
Owner of not so troubled puk :)
jonochap
Postby Neil » Sat May 11, 2013 4:14 pm
yeh but fuel tanks reading full all the time
Neil v6
Neil
Postby Vandalism » Sat May 11, 2013 5:05 pm
i dont know much about modern cars im afraid :lol: :roll:
but if it does fail atleast its an off the shelf part, not particularly hard to get hold of i assume
Postby jonochap » Sat May 11, 2013 5:30 pm
And sorry MB, good to see you about too...
jonochap
Postby mb4ever » Sat May 11, 2013 6:08 pm
Vandalism wrote:i dont know much about modern cars im afraid :lol: :roll:
Ah, if you've got a good wedge. :wink:
mb4ever
Postby OldHymer » Thu May 16, 2013 4:21 pm
I have a MK2 with powersteering, original Ford. '83 York Diesel left hand drive...
OldHymer
Postby mb4ever » Thu May 16, 2013 7:07 pm
OldHymer wrote:I have a MK2 with powersteering, original Ford. '83 York Diesel left hand drive...
That's rare beast you've got there Old Timer, please will you tell us about it?
Even some pictures perhaps?
mb4ever
Postby OldHymer » Fri May 24, 2013 6:10 am
All the RV's that are based on the Transit MK2 Hymermobil 522 with a diesel have powersteering.
A fat soft steering wheel with 3 square spokes, the oil pump is located near the left leaf front spring bracket, on a bracket attached to the engine.
The oil reservoir is screwed to the left inner wing.
There are 3 belts on my cranck.
OldHymer
Postby Neil » Fri May 24, 2013 6:51 am
german built :wink:
Neil v6
Neil
Postby mb4ever » Fri May 24, 2013 8:05 am
OldHymer wrote:All the RV's that are based on the Transit MK2 Hymermobil 522 with a diesel have powersteering.
Thanks OldHymer.
LHD then?
mb4ever
Postby OldHymer » Tue May 28, 2013 2:06 pm
OldHymer
Postby mb4ever » Tue May 28, 2013 3:48 pm
OldHymer wrote:http://www.ezpowersteering.nl/language/23/2/Home.html
Perhaps that is a solution...
Interesting OldHymer, thanks. :)
mb4ever
Postby mk2mania » Tue Jun 18, 2013 9:32 pm
weve done a few mk2 and mk3 electric power steering set ups,, all mint,, last one was a LHD 4x4 ex german fire truck ,, a minter with 21000 km Image
http://s187.photobucket.com/user/mk2mania/library/transit
mk2mania
Postby Neil » Tue Jun 18, 2013 9:57 pm
DOES IT CHOP INTO THE COLUMN OR BOLT ON
Neil v6
Neil
Return to Mk 1 & 2
