mb4ever wrote:baconsdozen wrote:Despite the fact that one of the thrust bearings was quite badly damaged and the other wasn't that far behind I was a bit disappointed on my test run.The steering isn't much lighter and I was hard pushed to notice any difference in self centering or what ever.
Bugger.
Have you checked: -
.........................Castor?
.........................Toe in?
Did you grease it with the weight on?
As well as with the weight off?
Urban myth I expect.
dumper wrote:You don’t it’s fixed from manufacture the only adjustment is the tracking.
dumper wrote:I think that is just a spacer to lift the ride hight on Diesel vans not sure if they fitted it to the later Petrol vans all they do is slightly increase the ride hight due to the extra weight of the York / DI engine I cannot remember if they fitted them on the Perkins in the mk 1 .
dumper wrote:Yes but it’s a solid beam axle the only way to change anything but the tracking is to bend the beam or stub axle
