madmark wrote:rudolf ,no the twin choke carb will not fit on your manifold, you will need to get a manifold form a ford corsair or english mk1 capri, i have fitted the weber 34ich to my 1.7 it runs alot better! and was a easy swap!
Rudz wrote:Hey Fred,
thanks for the answer ;o) Were you refering to fitting a sequential carb or an 34 ICH?
Could you give any information about changes in fuel consumption? Would be interesting...
The standard 34 ICH has a 29 main venturi, which cannot be changed. I could get one that has a 27 main venturi, 34 ICH as well. Does anyone have any idea, whether that is better, worse, or what?
Cheers,
Rudolf
MK1Chris wrote:Good post.
I've only had mine for a day and the first 180mile trip, my MK1 2litre V4 CI motorhome guzzled a tank and a half of petrol.
That's about 45 litres![]()
I was doing a steady 50mph all the way and as far as I know, everything like axle ratios and 4 speed gearbox are standard.
My daily driver is a Peugeot 406 coupe with a 3litre V6 and auto box and that seems to be very economical and positively sensible compared to the van ! ! !
MK1Chris wrote:
Good post.
Unless you are reading the liters off the petrol reciept, the LWB tank ins 68L, not sure about the SWB cos ours has the tiny 35L minibus tank.
FredTransit wrote:Rudz wrote:Hey Fred,
Cheers,
Rudolf
Not sure what you mean by sequential, I was talking about the Webber Twin choke conversion. Did the trick, and we didn't notice that much difference in the fuel consumption. I depends how heavy you are with your right foot!
