tow bar info?
tow bar info?
Postby ci motorhome man » Wed Jul 20, 2005 7:46 pm
can i get a tow bar for my ci moterhome? it's a coachbuilt so it's longer at the back end can it be done?if so does anyone know where i can get one?also a driver side mirror which was on the wing but now is in van heaven land i think i will put it on the door next time and fill the hole up on the wing thanx in advance andy ....
lets hope it's fine this weekend yeh?
ci motorhome man
Postby FredTransit » Wed Jul 20, 2005 10:15 pm
You will need a tow bar suitable for a chassis cab, we have one on one of our lutons, though the only use it has had is deflecting careless french drivers. The angle of the mirror arm is designed for the wing, and there are captive nuts for the fitting, though you could fit it to the door, it may not be so easy to see cos of the quarterlight frame. Has the old mirror rusted away, or was it stolen or damaged? Very important, if you still have it hang on to the plastic frame for the glass. You can still get the glass (we order them in packs of 10!) but the frames just aren't available anywhere. It's a trip to the scrappie for original mirrors, again if you can find them. The chassis cab arms are a bit longer. Also, the early sherpa mirrors (mis 80s) are a direct swap and have slightly longer arms. Even later sherpa/LDV mirrors can be made to fit (90s) and are OK if you don't mind them being not completely original. Hope this helps.
FredTransit
Mk2 Trannyist
tow bar info
Postby ci motorhome man » Thu Jul 21, 2005 8:42 pm
thanx fred yes i still have the mirror it's the same one they use on the cf's but i was worried about the fitting side of it cos at the mo it is still on the wing [just] cos it was hit and with the wing being a few yrs old decided to give way and left me with a nasty looking hole in the place where a mirror should be i shall have a few probs as i cannot get the back of the wing anyway thanxs again chat soon andy south wales...
ci motorhome man
Return to Mk 1 & 2
