mk2 power steering?
mk2 power steering?
Postby Aussie Ice Cream Van » Tue Mar 19, 2013 12:05 pm
Hi guys, does anyone know if the Mk2 came with powersteer, and could it be converted to a Mk1, cheers :D
Re: mk2 power steering?
Postby stoney » Tue Mar 19, 2013 12:51 pm
nope never did, but a mk3 power steering box can be fitted to a mk1 and mk2 problem is they are rare as rocking horse poo!
stoney
Postby 1977Camper » Sat Apr 27, 2013 9:51 am
I found this conversion. considering it for my Mk 2 but haven't yet as its not cheap
http://www.mk2mania.com/escort_mk3_4.32.html#transit
1977Camper
Postby mb4ever » Sat Apr 27, 2013 9:58 am
Get a similar power steerin box.
Fit it.
Modify the drop arm at your own risk.
mb4ever
Postby Vandalism » Sat May 04, 2013 8:44 pm
just keep your eye out for somone breaking a mk3 minibus, they usually have power steering...the one i found did :mrgreen:
Postby mb4ever » Sun May 05, 2013 9:29 am
Vandalism wrote:just keep your eye out for somone breaking a mk3 minibus, they usually have power steering...the one i found did :mrgreen:
Have you tried an LDV power steering box at all Vandalism?
mb4ever
Postby robert dale » Mon May 06, 2013 12:23 am
there are 2 ways to this problem;
1. refer to kiwi v8 site where he fitted a electric power steer unit.
2. i fitted a power steering box from a toyota 4 runner or hilux utes the units have to come from a leaf spring model, steering column from a xf falcon and xf pump
the pitman arm has to be resplined to fit the steering box, make new mounting bracket for the box to align with the steering column, the pitman arm from a toyota can be used but the connection hole to the drag link will need to be altered .
Bob
robert dale
Postby mb4ever » Mon May 06, 2013 6:02 am
robert dale wrote:there are 2 ways to this problem;
Bob
Any reason why you didn't simply weld the back half the Toyota drag link to the front half of the Transit drag link please Bob?
mb4ever
Postby Vandalism » Mon May 06, 2013 10:49 am
no i havnt as somone said it wouldnt fit, either due to the length of somthing or the drop arm bit being on the wrong side..ive been thoug to many different ideas i cant remember :lol:
Postby mb4ever » Mon May 06, 2013 2:03 pm
Thanks Vandalism
Does anyone know for sure if an LDV steering box will fit a Transit or not please?
mb4ever
Postby oldskooler » Tue May 07, 2013 7:07 pm
i looked into fitting an ldv one before and it involved a bit more chopping to the inner wing and chassis leg than id like. the ldv shell is a very different design where the steering box goes.
oldskooler
Postby mb4ever » Tue May 07, 2013 8:32 pm
oldskooler wrote:i looked into fitting an ldv one before and it involved a bit more chopping to the inner wing and chassis leg than id like. the ldv shell is a very different design where the steering box goes.
Thanks Oldskooler, interesting.
Have you seen the technique where you drill and tap some say 6mm steel plate to the same pattern as the Transit bolts holes.
Then drill the plate on the other side to match the power steering box holes.
That way you can fit the adapter plate to the power steering box, and using studs, bolt the adapter plate to the Transit chassis?
Would that method have saved chopping the Transit chassis leg please?
mb4ever
Postby Neil » Tue May 07, 2013 8:59 pm
power : steering :shock: why :?: just buy a mk 4
Neil v6
Neil
Postby oldskooler » Tue May 07, 2013 9:12 pm
not really, you id really need to see one and compare it to a transit to know what i mean. using a mk3 box and mounting plate is really the only tidy solution.
oldskooler
Postby mb4ever » Wed May 08, 2013 7:52 am
Neil wrote:power : steering :shock: why :?: just buy a mk 4
:D
I daresay there's as many reasons as there are people who'd like power steering on their early Transits Neil.
Probably, wishing to keep an important historic vehicle running on modern overcrowded roads, and accepting the limitations imposed by advancing years and stability play important roles. :wink:
A further factor is that early Transits were designed around cross ply tyres.
Cross ply tyres weren't exactly noted for their grip, so they didn't make steering heavy at low speeds.
Modern radials exert far more grip, and therefore make steering at low speeds much heavier.
In '66
mb4ever
Return to Mk 1 & 2
