locking fuel pump on mk2
Postby batfink82 » Thu Aug 04, 2005 4:16 pm
hi,
im replacing the timing belt on a mk2 diesel, i cant see how to lock up the fuel pump......any suggestions would be greatly received
cheers :cry:
batfink82
Postby madvanman » Thu Aug 04, 2005 4:40 pm
You will need a diesel lock pin kit, you have to put 1 pin through a hole at the back of the block on offside to lock the crank, 1 pin through the cam pully to lock the cam and a pin through the pump pully to lock the pump,
when you manage to get 1 of these pins lined up the others should both line up.
madvanman
Customised!!
Postby batfink82 » Thu Aug 04, 2005 5:04 pm
thanks, ill give it a go......
batfink82
Postby Luke » Thu Aug 04, 2005 5:51 pm
If your a northerner, you might find using drill bits (like i did) cheaper than buying a kit!!! :lol:
and also make sure you have removed them all before trying to run it!!! :lol: :oops: :lol:
Postby batfink82 » Thu Aug 04, 2005 6:19 pm
lol, am a southerner but still used the drill bits
batfink82
home made locking pins
Postby rottie_007 » Mon Nov 14, 2005 8:42 pm
I wasa mechanic for 13 years and found a cheap set of long 1/4 drive sockets would pretty much emcompass the full ratio of locking pins on most engines....
and having the wide base they locked nicely into place
1979 mk2 pre facelift CI campervan " Bessie Brown "
1994 Pug 405 est " George "
1998 pug 106 "Mildred"
rottie_007
Return to Mk 1 & 2
