302 v8 into transit mk1 ????
Postby supervan 1 » Wed Sep 07, 2005 4:30 pm
i kown everything is possible with a gas axe and large grinder and a mig but its a big BUT has anyone put this ford yank v8 into a tranny before ??? with or without transmision andy
supervan 1
Postby madmark » Wed Sep 07, 2005 8:01 pm
and i was originaly going for a 302 some years ago ,i decided to go rover instead as the ford engine was very heavey! :D
Postby supervan 1 » Thu Sep 08, 2005 8:42 am
i was thinking about this engine cos of the price of a re build the parts on a 302 are half as much as an essex weight wise id have thought the diffrence woudnt be that much woukld it ????????? andy
supervan 1
Postby madmark » Thu Sep 08, 2005 11:38 am
:? now that s a good qeustion,the 302 is still cast so i would of thourt it must way more than the essex! :? is your 3ltr needing a rebuild ????? :D
Postby supervan 1 » Thu Sep 08, 2005 2:04 pm
its not that it needs :wink: a rebuild its just bloody slow 60 mph on the flat 40mph on a hill mind you pullin around 2 ton ish it dont do bad the way i was thinkin was v8 302 built for torque i wouldnt need to rev the tits of it to move it as yanks say theres no substitute for cubic inches :lol: :lol: saying tha ive just read a add in a certain mag and in there theres a twin turbo cossie 2.9 auto going cheap {£600 ono } not to far away neither :twisted: :twisted: ahh decisions decisions :roll: :roll:
supervan 1
Postby madmark » Thu Sep 08, 2005 6:14 pm
mate what carb is on your engine????? it should pull better than that ! i had a camper along wile ago with a v6 that i fitted and it was a twin wheeler similer size to yours and it went like a bomb! :?
Postby supervan 1 » Thu Sep 08, 2005 8:00 pm
the carbs a 40dfav the gearing is 4 speed overdrive 4. 1.1 rear diff ratio im lookin for a 38 d gas cheaked the tapets this afternoon the ex valves were a little on the tight side so re set all inlets to 13 thou exh to 22thou runs ok but still 55 60 on the flat :cry: its begining to #iss me off :? :? any ideas :idea: :idea: :idea: andy
supervan 1
Postby FredTransit » Thu Sep 08, 2005 8:44 pm
We have a 351 in our stretch, but there is a lot more room in a Mk2!
FredTransit
Mk2 Trannyist
Postby pete_the_4x4 » Tue Sep 13, 2005 11:21 pm
go for it get rid of that old v6 then you can go for ally intake and heads makes them a lot lighter and you get more power
if you think my van is dirty you should see my pants
pete_the_4x4
Postby supervan 1 » Wed Sep 14, 2005 2:51 pm
:D :D :D i've sussed the slow speed issue belive it or not :shock: it's been governd by using an limiter on the ignition side of things i fitted a rev clock would not rev underload past 3k ie top gear 50 55 mph did a little hot wire job cut out the eleci ignition now pulls like a train :twisted: 70 mh nooo problem So boys and girls has this thing been fitted cos of the "drives like a bungalow on ice " and at 70 mph you could wipe you and half the m6 out me wonders :?: :?: :?: andy
supervan 1
Postby FredTransit » Wed Sep 14, 2005 3:03 pm
I take it this isn't an original addition? Can't see a limiter being a Mk1 thing, mostly brute force and ignorance in the 70s...........
FredTransit
Mk2 Trannyist
Postby UK_ANDY » Wed Sep 14, 2005 3:35 pm
Your problem could be just that the electronic ignition unit has developed a fault years ago i had the same problem with a triumph bonneville fited with electronic ignition changed the amplifyer and the prob was solved :D
old ford's never die they just go faster
Click here to vote for the forum in the Ford top 50 sites!!
UK_ANDY
Postby supervan 1 » Thu Sep 15, 2005 2:49 pm
took off the elec ignition this morning pulled it apart inside guess wot i found :roll: :shock: inside a dial to set the revs !!!!!!! and yes its set at 3500 rpm it does go to 8 k tho but i dont trust it ill leave it the conventinal points set up less hassle :D update took it to a local motor factors who tests ignitions says its ok but i think ill ebay it any way LOL andy
supervan 1
Postby madmark » Fri Oct 21, 2005 1:36 pm
:shock: i have noticed that the eletronic ign that came with my engine has a limiter fitted ,but dont know what its set at and dont want to touch it incase it goes wrong! the make of mine is lumignition i think! :?
Postby cad69 » Tue Nov 15, 2005 11:52 am
yo
Had the good fortune to look at a Mk1 on the weekend that had a 350ci under the bonnet/hood. It looked surprising small but that is because it was sitting pretty low. Oh... the 350 ci is a 302 that had been stroked. 100k's (60mph) in 1st, 160k's (100mph) in 2nd. Been blue printed etc and redlined at 7200. Never thought to get a photo... next time.
Cad
cad69
Return to Mk 1 & 2
