rear diff mk1 swb bus
Postby FFP » Tue Jun 19, 2007 7:33 am
Good morning,
I have a 1.5 swb 1969 bus, it has a single wheel round rear axle (atlas?)
1250kg empty
i'm installing a modern tdi/jtd engine with a 4 speed OD as im planningt ouse it as daily transport
I'v been told that the v6 capri diff wil fit
Is this correct, as i'm planning to instal a 3.22 or 3.09 diff
are the splines etc the same when converting this diff
I', looking for +/- 2000rpm @60mph for milage, the tdi engine has max torq (250nm) and combined best milage at these revs
I'v calculated the needed kw en nm at several speeds ( with air and rol resistance etc even the fuel efficiency graphs of different engines) and these match the engine pretty good
so wil the diff fit, and does anybody have experience with modern diesel engines in brick like air-resistence big frontal area vans
greets ,
marc
dont buy it, build it
FFP
Re: rear diff mk1 swb bus
Postby FFP » Wed Mar 12, 2008 8:18 am
I wil post some pictures same day tomorow, as there were no reply's to the questions asked
i'v got a 1.6 gtd engine in right now, fits ok with vw radiator. stil leeves space for the intercooler and very thin. (gtd hase the same dimentions as any vw 4cyl)
makes for great conversions as the vw engines are very universal, you can fit 150 bhp tdi, G60 or 20vt engines. even vr6 engine will fit in flat front
made a conversion plate for a 4 speed OD gearbox to the vw fwd bellhousing and schortened the Propshaft
gearbox is about 2 inch back from original ( bent gear lever)
gr Marc
FFP
Postby rover » Wed Mar 12, 2008 8:49 am
Sounds very interesting, did you find a diff to fit?
Look forward to the pics. :D
Rover.
rover
Postby Luke » Wed Mar 12, 2008 9:33 am
i wouldn't mind seeing some pics either 8) :D
Postby madmark » Wed Mar 12, 2008 2:53 pm
if you had the tube type axle then its possible to fit a 3.44 or even 3.09 with a bit of modification. if you have the normale type square axle then no 3.9-1 is the lowest ratio :wink:
Postby FFP » Wed Mar 12, 2008 4:33 pm
its the older, round axle type with inspection plate at the rear
3.09 with modification?? what mods? the casing should be the same as capri??
conversion took more efford than expected
hydrolic clutch, waterhoses, engine and gearbox mounts etc.
how do I post pictures?? hyperlink?
gr Marc
FFP
Postby Luke » Wed Mar 12, 2008 4:34 pm
FFP wrote:how do I post pictures?? hyperlink?
instructions are here :arrow: viewtopic.php?f=15&t=23 :D
Postby FFP » Thu Mar 13, 2008 8:24 am
signe up doesnst work at photobucket, cant get pictures there
is there a info@transitforum?? can e-mail the pictures
not that handy with computer stuf
gr Marc
FFP
Postby FredTransit » Thu Mar 13, 2008 4:11 pm
Try image shack http://imageshack.us/, it's a pretty easy site to use.
FredTransit
Mk2 Trannyist
Postby Luke » Thu Mar 13, 2008 7:42 pm
FFP wrote:signe up doesnst work at photobucket, cant get pictures there
gr Marc
yeah mate email em me admin@fordtransit.org i'll post em :D
Postby BROWNYS V6 » Thu Mar 13, 2008 8:08 pm
modifications :?: dont need any of that bolted straight in when i did my original diff swap to 3.09 gears. i am now in the process of building an atlas with 2.8 capri lsd with 3.44 gears will try to put up a pic later.halfsharts slot straight in :D
BROWNYS V6
Postby madmark » Thu Mar 13, 2008 8:19 pm
i had 3.44 in mine years ago with the rover v8 :wink:
Postby BROWNYS V6 » Thu Mar 13, 2008 8:22 pm
not sure whether it will be any good with these in but i dont like the standard ratio in the square tube axle so we shall see :?: :D
BROWNYS V6
Postby madmark » Thu Mar 13, 2008 8:26 pm
in the square type axle 4.11 is a nice ratio the problem is the lower you go in numbers its harder to get the power ,as you are pushing along a brick ,over gear it and you will die on the hills like my mk1 ha ha :lol:
Postby FFP » Mon Mar 17, 2008 8:13 am
emailed the pictures
its running now so il take some new pictures incl intercooler etc
working on clutch and exhaust right now
gr Marc
FFP
Return to Mk 1 & 2
