Mk2 pinto to early di conversion
Postby Retrohowla » Sat Jul 07, 2007 9:32 pm
Thinking of replacing the thirsty 2.0 pinto with a 92 di
Its a lwb mk2 and a few people have raised concerns around pulling power, will it be that sluggish? :?:
If you own a transit, learn to weld
Retrohowla
Postby Retrohowla » Sat Jul 07, 2007 9:37 pm
Sorry, prob not enough info
My van is a 1981 lwb single wheel fitted with a 2.0 pinto and 4 spd box
Proposed replacement is a 1992 2.5 di with 5 spd box
Retrohowla
Postby Luke » Sat Jul 07, 2007 9:49 pm
di will have more pulling power, but will probly be slower un loaded :?
worst thing with Di's in mk1/2's is the noise :x
Postby Retrohowla » Sat Jul 07, 2007 9:50 pm
Right thats not too much of a drama, well if i get more than 15-20mpg out of the di it will be an improvement on the pinto
Retrohowla
Postby Retrohowla » Sat Jul 07, 2007 9:51 pm
Any ideas on improved performance on the early di's?
Retrohowla
Postby Retrohowla » Sat Jul 07, 2007 10:29 pm
Thanks for the info, the main reasons for the swap are mpg, reliability and the fact that the pino is very cammy and the box is pick a gear any gear!
But you say the pinto with 5 speed is the way to go?
Will it bolt sraight on?
What about prop length?
Retrohowla
Postby Neil » Sat Jul 07, 2007 10:34 pm
try a v6 essex
Neil v6
Neil
Postby FredTransit » Sat Jul 07, 2007 10:35 pm
Niel I think he was looking for better economy :wink:
FredTransit
Mk2 Trannyist
Postby Neil » Sat Jul 07, 2007 10:39 pm
should get another 3 mpg on a pinto
Neil v6
Neil
Postby Retrohowla » Sat Jul 07, 2007 10:39 pm
So would i have a type 9 on the 92 di?
This box has been pretty good for me for around 35 thou so far in the swb
As i have the di and box from my 92 swb would this not be a sensible option?
Forgive my lack of knowledge but i ran a 2.0 pinto in my capri for years and although good just never matched the di for out and out dependable reliability so figured better the devil i know with the donor parts as opposed to cammy smokey pinto i have no history on?
But if you think a rebuild and mt75 would suit better for the long run?
I am getting lost now!
Retrohowla
Postby Retrohowla » Sat Jul 07, 2007 10:43 pm
Essex was considered for a moment (or maddness) as three sat on the drive but just not what i am after
Few more mpg, reliable workhorse easy swap on a budget is what i am after
Retrohowla
Postby Retrohowla » Sat Jul 07, 2007 10:48 pm
Like a dunce i am sat here asking what box i have when i changed the bloody prop it was a bolted flange so its mt75?
So with this box in mind what would you go for, cammy pinto or trusty old di?
Retrohowla
Postby Retrohowla » Sat Jul 07, 2007 10:51 pm
Just like to say i really appeciate all your advice just get confused with numbers and stuff and come across blunt, no offence!
Retrohowla
Postby Luke » Sat Jul 07, 2007 10:54 pm
in my mk1 pickup and my mk4 van - ive fitted Di's reliable torquey motor :D
but in my minibus (my best one) i wouldnt have a Di far too noisy :lol:
Postby Retrohowla » Sat Jul 07, 2007 10:56 pm
cheers luke, think as i have the donor van its a sensible option, do you know anything about the wiring from petrol to diesel?
Retrohowla
Return to Mk 1 & 2
