Differential oil change on a MK2 1980 Transit
Postby andrericardo » Mon Apr 10, 2017 8:19 am
Hi guys
I really need help here...
I need to change the diff oil on my transit and after looking at it i have no idea how to do it, as there is no plug...
Also searched for tutorials , videos or any information online, and found nothing... :(
andrericardo
Re: Differential oil change on a MK2 1980 Transit
Postby Luke » Mon Apr 10, 2017 8:56 pm
you can use a cheap oil pump/sucker like this :D
Postby andrericardo » Tue Apr 11, 2017 7:59 am
but where do i insert the tube?
i see no drain or plug on the diff? is there one? if so, where?
andrericardo
Postby whitemice » Tue Apr 11, 2017 9:00 pm
look for square socket filler plug on front of diff and remove and insert tube there, use the drive on a wrench to undo.
https://www.youtube.com/watch?v=jIaGWURONRU
'' VOTE Kim Jong Unwell.
Mike writ '' a vote for lABOUR is a vote for islam and a conservative vote is a vote for islam and a vote for liberal is a vote for islam. ''
DBVM ''a vote for UKIP is a vote for islam''
whitemice
Location: normalised heavily chemtrailed cretinous individual just like you
Postby Muttley » Tue Apr 11, 2017 9:21 pm
If you dont mind some spannering then remove prop and halfshafts and unbolt the diff, just loosen it and all the oil will come out :wink:
Expert burns receiver.
Bodger Extraordinaire!!
Fallen in love/hate with Mk6s
Muttley
Postby whitemice » Tue Apr 11, 2017 9:25 pm
Muttley wrote:If you dont mind some spannering then remove prop and halfshafts and unbolt the diff, just loosen it and all the oil will come out :wink:
:lol: :lol: :lol: :twisted:
whitemice
Postby 1958 harry » Thu Apr 13, 2017 11:29 am
What do you use for a gasket on the rear diff, if you remove the cover?
VW Transporter Combi van
VW Beetle 2.0 tintop
Audi Q3 Quattro SLine Plus
Grown up in/around Transits, my dad has a 2010 115 T350 Transit
1958 harry
Postby Muttley » Thu Apr 13, 2017 9:48 pm
A diff cover gasket, or sealant if its a front loader :wink:
Muttley
Postby 1958 harry » Thu Apr 13, 2017 10:15 pm
Can you buy the gaskets anywhere for the twin wheeler back axles?
1958 harry
Postby Muttley » Fri Apr 14, 2017 9:50 pm
I have seen them on the bay but not recently, you can make one out of heavy gasket paper using the cover as a template.
Muttley
Postby Timelourd » Sat Jun 22, 2019 11:59 am
The manual for my '96 says to unbolt the cover and the oil comes out. Then I'd have to change the gasket, and get new screws, then just put the cover back on. They recommend not messing around with the differential itself, at all. I'm going to listen to them.
Not sure what yours looks like, though, but I'm only saying this because there's definitely no fill/drain valve on mine either.
1996 2.5di MK5 Banana Engine
Timelourd
Return to Mk 1 & 2
